OEM Hardtop Defroster Question
Had a quick question. Bought an OEM Hardtop with out oem hardware. Decided to buy the FORBIDDEN-USA rear latches due to how ridiculously expensive the Honda rears are. Picked up everything else from Hardtopguy. So when from what I have read the drivers side OEM rear latch has a pressure switch in it that activates the hardtop defroster to be able to be use. Since I'm using forbidden latches, can i just cut off the 2 pin connector on the sub harness and wire in an a simple on/off switch to switch between the hardtop and softtop defrosters?
Hopefully I posted this in the right place.
Thanks in advanced.
Thanks in advanced.
Does the OEM latch have a pressure switch, I thought the plug is what activates the defroster?
From the limited amount of info I've been able to find, one end of the defroster sub harness plugs into a prewired socket behind the seats, the other end is for the pig tail from the top its self and the the middle 2 pin connector plugs into the drivers side rear latch. The only description of what the wiring in the latch is for that I have been able to find is from a reddit post. "For this purpose, the driver side catcher assembly has a pressure switch in it to detect when the hard top is installed, cutting the soft top circuit."
Never heard that before. I always thought it was the wire from the hardtop to the covered plug that activates the defroster. Does your hardtop come with the OEM pins at least?
Installed the hardtop this weekend so, I went ahead and wired it up to a 3 Amp on off switch and mounted it in the panel with the clothes hooks on behind the seat. I haven't gotten to test the defroster yet, but I did check it with to see if it was working when a multi-meter when I installed it. With the switch on (and the defroster on) I was reading ~12 volts at the plug for the hardtop pig tail and it dropped to 0 volts with it off.
How's the fitment of the Forbidden hardware? Got any pics?
