DocTronics Plug & Play Honda S2000 ECU for 2000-05 Models
Old 07-19-2016, 05:24 PM
BalladeSports's Avatar
Default DocTronics Plug & Play Honda S2000 ECU for 2000-05 Models
Hello everyone!
For some time now an ECU solution for 2000-2005 S2000s have only been EMS, Infinity and Hondata KPro.
EMS and infinity are very nice with all of their functions, but the lack of OBD2 port connection and cel makes it much more suitable for Race cars versus street cars.
Hondata Kpro is an excellent solution. Using a Honda K series ECU modified to be used for an S2000. All the pros of ecu mapping and daily functions of the Honda ECU make this a real winner. The biggest inconvenience is the necessity to convert the cam sensor, crank sensor and valve cover along with the pick up wheels. Its a lot of work to convert and when come time for smog, difficult to revert back.
Doctronics, located out of Austria have been able to provide us with a K Series ECU, much like Hondata Kpro, without having to convert the cam and crank sensors. They have cleverly created a Mag to Hall signal converter and a jumper harness to mate a re-programmable K ECU for the use of our 2000-05 model S2000. This unit is called ProECU-S2K
If you are familiar with Kpro software, then you can handle the new software created by them. Very easy to understand and simply plugs right into the stock engine harness. Supports Supercharge, Turbo, and Nitrous applications just like competing software solutions.
We at Ballade Sports have become direct distributors to this revolutionary ECU managment and would like to share their features:
Product Description
This is a S2000 programmable Tuning ECU made by converting a Honda/Acura K series RSX ECU to meet the functions and needs for the 2000-2005 drive by CABLE S2000 models.
No need to change any sensors.
It contains a K-Series ECU including a License of our K-Series Tuning Solution ProECU-K and an active Adapter Harness.
All Sensors, Crank, Cam and IAT Sensor can remain stock.
Even the S2000 Gauge Cluster (Engine Coolant Temperature) is supported and controlled by the ECU/Software.
Features:
• Plug-n-Play, no need to change any Sensors
• Supports the S2000 Gauge Cluster Engine Cooland Temperature display
• All the features of ProECU-K
• Edit Fuel, Ignition Tables
• Expanded Tables for Boost (20x20 Cells)
• VTEC Control incl. full VTEC Window
• Idle Control
• Rev Limiters, Fuel and Ignition Cut
• Shiftlight by Gear
• Launch Control (2 Step) by Ignition Cut
• Flatshift (3 Step) by Igniton Cut
• Flatshift by Gear
• Lambda Control
• Boost Control by Gear
• Nitrous Control
• And much more …
ProECU-S2K includes:
• K-Series ECU
• active Adapter Harness
• USB Connection Cable
• Softwarelicense for the Tuningpackage
• (Software as Download from our Server)
System Requirements for the PC Software:
Windows XP, Vista, 7, 8.1
CPU 1 GHz+
Ram 1 GB+
Harddrive 10MB+ free
USB 2.0 Port
[media]http://www.youtube.com/watch?v=PPlTWV40Mfw&feature=youtu.be[/media]
We at Ballade Sports have tested this software and ECU ourselves on our standard F20C/F22C engines and our K24 I-Vtec S2000. We are very impressed with its capabilities and ease of use. It is compatible with K series engines along with F20/22/24 engine platforms.
More info on our website: https://www.balladesports.com/produc...ecu-proecu-s2k
Old 07-23-2016, 05:38 PM
Chitoki's Avatar
Nice, does it support flex fuel and wbo2 feedback?
Old 07-25-2016, 05:53 AM
Micalbertl's Avatar
staying tuned to learn more on this
Old 07-25-2016, 10:26 AM
First successful Dyno test with our new Doctronics K Series ECU. Plug and play for 2000-05 S2000. Full dash ECT compatible along with AC, EPS and all the factory functions and check light notifications.
Old 07-26-2016, 06:00 AM
stack's Avatar
Please provide some more details on the software, ie screenshots or a link to download a trial version.
Old 07-26-2016, 09:05 AM
http://www.doctronic.at/Download_E.html
All of the software downloads are readily available directly off the Doctronics website.
Old 07-26-2016, 09:29 AM
Micalbertl's Avatar
Still waiting to hear if this can tune for flex fuel
Old 07-26-2016, 09:42 AM
We are still looking into this support. We personally have not tried with this ECU setup yet. Wideband is supported for additional fees.
Old 07-26-2016, 09:43 AM
Old 07-27-2016, 06:26 PM
R00567's Avatar
1) Do you retain the OBD port? will it scan with an emissions tester?
2) can you set readiness like in Kpro (for k series) to pass emissions?
Quick Reply: DocTronics Plug & Play Honda S2000 ECU for 2000-05 Models
