AIT Temperature increase during WOT
#51
I thought I should mention that I run an air to air and I stay ambient temp with water/meth in boost I did a log 2 days ago in 95 degree weather and my iat's where 85-90 degrees with the sensor in stock location.
#52
I could of done this last year when I upgraded CT my kit to the Novi 1200 revision, but I wasnt aware that the SOS provided more cooling by a bigger AC, I thought they were comparable?
#54
Jim is there no way you could fit an aftermarket aftercooler using silicon hoses and a t-piece for the bypass/BOV
There are some good barrel type coolers available but they arent cheap £600 or so but seem to be highly rated.
#55
Yeah thought about that. I'm going to install a fan on my front heat exchanger after talking to AVT in the UK.
If that doesn't keep the coolant cool and lower AIT then a bigger aftercooler is going in
#56
So after a bit of further investigation I found that when I fitted my Amuse R1 bumper one of the pipes in the aftercooler system got kinked. I'm hoping to see lower AIT's at the Nurburgring this weekend
joefish1298
07-20-2012 05:57 PM
