AIT Temperature increase during WOT
Old Aug 23, 2016 | 01:35 PM
  #51
s2k manic's Avatar
Originally Posted by E4RTH WORM JIM
I run 19psi @ 9200
I just don't want to extend my wiring for this mod . I didn't realise the 06+ cars have the AIT sensor in a different location.
I thought I should mention that I run an air to air and I stay ambient temp with water/meth in boost I did a log 2 days ago in 95 degree weather and my iat's where 85-90 degrees with the sensor in stock location.
Old Aug 24, 2016 | 09:11 AM
  #52
E4RTH WORM JIM's Avatar
Originally Posted by RAIN H8R
Depending on the market, you could sell your sc kit and but a new sos sc kit for a little more money out of pocket. This is comparing it to buying or building an sos sized aftercooler for your curgent kit.
Sos has a better tensioner for the pulley belt, too.
I could of done this last year when I upgraded CT my kit to the Novi 1200 revision, but I wasnt aware that the SOS provided more cooling by a bigger AC, I thought they were comparable?
Old Aug 24, 2016 | 10:26 AM
  #53
Also what temperature increase do you see through a WOT pull?
Old Aug 25, 2016 | 09:28 AM
  #54
markforrester99's Avatar
Jim is there no way you could fit an aftermarket aftercooler using silicon hoses and a t-piece for the bypass/BOV
There are some good barrel type coolers available but they arent cheap £600 or so but seem to be highly rated.
Old Aug 30, 2016 | 07:55 AM
  #55
Yeah thought about that. I'm going to install a fan on my front heat exchanger after talking to AVT in the UK.
If that doesn't keep the coolant cool and lower AIT then a bigger aftercooler is going in
Old Sep 5, 2016 | 09:31 AM
  #56
So after a bit of further investigation I found that when I fitted my Amuse R1 bumper one of the pipes in the aftercooler system got kinked. I'm hoping to see lower AIT's at the Nurburgring this weekend
spectacle
Jun 28, 2016 03:42 AM
Hondatuner82
Apr 22, 2014 05:56 AM
joefish1298
Jul 20, 2012 05:57 PM
mikecl713
Dec 4, 2003 09:17 PM
