14mm 1.5 pitch self tapping bolt
Old 06-14-2008, 02:36 PM
rikhemi's Avatar
Default 14mm 1.5 pitch self tapping bolt
Went to a local auto store "Advanced auto parts" but they didnt have the correct size. I tried looking online but couldn't find it either. Anyone know of any places I might be able to find it locally or on the internet.
Thanks
Old 06-14-2008, 02:42 PM
a_zepeda926's Avatar
sears?
Old 06-14-2008, 05:28 PM
jeggy's Avatar
snap-on website.
matco website
McMaster carr website.
Old 06-14-2008, 07:18 PM
rikhemi's Avatar
I went to 3 other autopart stores and all they seem to have is 14mm by 1.25.
Ill try sears out tomorrow. If not I'll just have to order it online.
Old 06-15-2008, 12:37 AM
Sleeper2000's Avatar
[QUOTE=rikhemi,Jun 14 2008, 02:36 PM]Went to a local auto store "Advanced auto parts" but they didnt have the correct size.
Old 06-15-2008, 10:35 AM
Sorry, i was thinking of a tap and die set But yea a local hardware store should have it.
Old 06-15-2008, 11:15 AM
rikhemi's Avatar
Just to clarify, this should be the correct size on our oil pan if the thread is stripped?
Old 06-15-2008, 11:22 AM
Slows2k's Avatar
14x1.5 is the original drain plug's size.
If the pan is stripped too badly a tap isn't going to fix it.
Old 06-15-2008, 06:51 PM
rikhemi's Avatar
Well went to a ace hardware which carried the taps. They advised me that I should go with the next higher size since the pan was stripped. They said a 9/16 tap with the correct plug would be sufficient since its slightly larger than 14mm. I belive its around 14.5 mm
Does this sould right. I felt it makes sene since if the oem size is 14mm x 1.5, why would you tap the same size.
Also, this is for a pt cruiser with a aluminum pan. Are there any precautions I should take to prevent it from potentially cracking. The 9/16 is barely bigger so it shouldn't cause an issue but I wasn't sure. Ive read that they sell an oversize drain plug which taps itself as its threaded. Could this be another option?
Thanks again
Old 06-16-2008, 01:00 AM
[QUOTE=rikhemi,Jun 15 2008, 06:51 PM]Well went to a ace hardware which carried the taps.
Chitoki
06-01-2017 07:15 PM
nichigo
11-26-2007 06:25 PM
krazik
06-21-2007 02:53 PM
d.h
02-01-2006 04:10 PM
chikai
08-29-2005 04:32 PM
Quick Reply: 14mm 1.5 pitch self tapping bolt
