HOW-TO: Wiring Hondata Boost Solenoid
Old 02-15-2010, 04:41 AM
spectacle's Avatar
Default HOW-TO: Wiring Hondata Boost Solenoid
I get a lot of PM's on this so I want to post up the information for all to see. Hopefully this gets into the FAQ and can be seen through a search.
You don't not need to go all the way to the ECU to wire in the MAC/Hondata solenoid. You can use the wires that go to the purge valve inside the engine bay.
On the drivers side find the big ABS unit. Theres a big wiring loom going into that...inside of that loom there is a smaller loom containing 2 wires going towards the engine block.
The wires are black and red with a yellow stripe. Snip off the connector going to the purge valve and connect up the boost controller wires to them, IIRC the wire order does not matter.
I know all AP1's have this connection and I'm assuming cable throttle AP2's do as well, not sure about the DBW AP2's.
Old 02-15-2010, 05:31 AM
GpWaP1 s2k's Avatar
So you don't use the purge valve? Is there anything different you need to do when you go into the K-Manage software?
Old 02-15-2010, 06:25 AM
spectacle's Avatar
No purge valve. It ain't doing much anyway.
Yes, you have to activate the boost controller in kpro. Very straightforward if you're familiar with the software.
Old 02-15-2010, 11:51 AM
GpWaP1 s2k's Avatar
Thanks for the info man.
Old 05-13-2010, 09:35 AM
Irishflame27's Avatar
just wondering if this only applies to Kpro? so when hooking up the boost control solenoid to these wires, it wires it into the B21 (PCS) pin?
Old 05-14-2010, 06:43 AM
anyone?
Old 05-14-2010, 01:46 PM
spectacle's Avatar
Correct
Old 05-12-2011, 08:13 PM
Bump for awesome info! I hope all the kpro guys are doing this!
Old 05-19-2011, 09:58 AM
spectacle's Avatar
Please add this to the FAQ
Old 05-19-2011, 10:25 AM
Corey Maurer's Avatar
Work with AEM on MAC solenoid too?
Quick Reply: HOW-TO: Wiring Hondata Boost Solenoid
