Oil Leak from VTEC Solenoid...
Old 04-18-2010, 06:56 PM
toniotran's Avatar
Thumbs up Oil Leak from VTEC Solenoid...
Hi All,
I apparently have an oil leak that seems to be coming from one of the bolts located on top of the vtec solenoid. To be precise there are 3 bolts that are mounted on top of the vtec solenoid and it is the 1 pointed outward in the same direction as the vtec pressure switch. After unscrewing all 3 bolts and removing the top cover of the vtec solenoid there is a rubber gasket, I went to the dealership assuming that I would be able to order it but the only gasket available is the one with the filter . If any knows where I can order the gasket as shown in the diagram below or what I could possibly do to stop the oil leak please chime in.
TIA,
Tony
Old 04-19-2010, 10:18 AM
s2ke5's Avatar
I had the same exact problem and ended up ordering the gasket with filter from the Honda dealership. I couldn't find just the gasket either.
Old 04-19-2010, 11:08 AM
my2ks2k's Avatar
just buy the kit, it's not expensive
Old 04-19-2010, 02:15 PM
toniotran's Avatar
This one?
The one that I need is the "upper" gasket like the one shown in the 1st pic and not the one w/ the filter that goes between the vtec solenoid and the block, and from what it looks like I wasn't able to find the part number for it
similar to this:
Old 02-05-2012, 10:32 AM
fri3dric3boi's Avatar
sorry to bump but does anyone know the part number for the top gasket?
Old 02-26-2012, 12:13 AM
jonathanyip343's Avatar
I have the same question. Who know the part number ?
Old 02-26-2012, 09:18 AM
Billman250's Avatar
Received 1,253 Likes on 763 Posts
Not available. Need to buy a VTEC valve to get it.
Old 02-26-2012, 04:00 PM
s2000ellier's Avatar
36172-P08-015 017 001 GASKET, SOLENOID BASE 7.80 5.46
I just replaced one on my 97 prelude, i'd bet they're interchangeable
Old 02-27-2012, 08:31 AM
nissanfanatic's Avatar
15825-PCX-015
http://www.hondaauto...+VIN+Number+---
Item 14
Old 02-27-2012, 10:18 AM
SgtB's Avatar
Originally Posted by nissanfanatic
That's a different gasket. The solinoid assembly has two halves and there is a gasket that isn't listed for the S. It's number 17 in the link I posted, and looks exactly like the one the OP posted.
Quick Reply: Oil Leak from VTEC Solenoid...
