Diy-Rpf1 Center Caps using oem honda caps
Not sure if there is diy for RPf1 center caps using oem honda center caps but here it is hope its useful for some of you
So i used the following products
Center caps from CR-V 05-06 (16x6-1/2), alloy, 10 spoke Honda part#44732-S9A-A00
Red H decal bought from ebay
Rust-oleum satin black spray paint
I did this on my rpf1 17x9+45 not sure if any other offset is different
Sand the cap down with a 400 grit sand paper
Shave the center of 2 caps for the rear because they touch the axle nut this is to prevent them from falling off
i used a dremel
Spray them
then center the decal and stick it on
i used a dremel
Spray them
wow! where exactly did you get the center caps? I'm guessing our stock center caps wont fit?
I found these on eBay:
https://www.s2ki.com/s2000/topic/912...#entry21192750
I'm hoping these are the right ones?
