Diy-Rpf1 Center Caps using oem honda caps
Old 11-27-2011, 01:01 PM
Pabs626's Avatar
Default Diy-Rpf1 Center Caps using oem honda caps
Not sure if there is diy for RPf1 center caps using oem honda center caps but here it is hope its useful for some of you
So i used the following products
Center caps from CR-V 05-06 (16x6-1/2), alloy, 10 spoke Honda part#44732-S9A-A00
Red H decal bought from ebay
Rust-oleum satin black spray paint
I did this on my rpf1 17x9+45 not sure if any other offset is different
Sand the cap down with a 400 grit sand paper
Shave the center of 2 caps for the rear because they touch the axle nut this is to prevent them from falling off
i used a dremel
Spray them
then center the decal and stick it on
Old 11-27-2011, 04:58 PM
Kid Ap2000's Avatar
looks perfect
thanks for posting
hope these help
Old 11-27-2011, 05:07 PM
lilrotor's Avatar
Looks good, glad I could help with the part #
Old 11-28-2011, 12:20 AM
Pabs626's Avatar
Thanks lilrotor couldn't of done it with out you
Old 11-28-2011, 05:51 AM
AngryTurtle's Avatar
There should be a lot of people with rusty hubs loving you.
Old 11-28-2011, 07:28 PM
corpuszero's Avatar
wow! where exactly did you get the center caps? I'm guessing our stock center caps wont fit?
I found these on eBay:
https://www.s2ki.com/s2000/topic/912...#entry21192750
I'm hoping these are the right ones?
Old 11-28-2011, 09:32 PM
Pabs626's Avatar
I bought all 4 of them from eBay for $20
Old 11-28-2011, 09:41 PM
Former Sponsor
Shadow_S2K's Avatar
I believe you can use the 2002 Accord center caps.
Old 11-29-2011, 06:24 AM
Pabs626's Avatar
I believe they used those center caps on multiple cars as long as the part# is the same ur good
Old 12-01-2011, 08:18 AM
midnightmethane's Avatar
wow awesome DIY wuth everything in it...was def planning on doing this over the winter...thanks a lot for posting...and black RPF1's FTWWWWWWWW
Quick Reply: Diy-Rpf1 Center Caps using oem honda caps
