Anyone With Ap2 Shop Manual - PCV Valve Torque Spec ?
Old 04-08-2012, 07:43 PM
zeroptzero's Avatar
Received 3,373 Likes on 2,452 Posts
Default Anyone With Ap2 Shop Manual - PCV Valve Torque Spec ?
I've asked this before but never came up with a suitable reply. I run an ap2 valvecover on my ap1, I have an ap1 shop manual but it doesn't list the torque spec that I need for an ap2 pcv valve. My ap2 pcv valve is leaking oil recently and it is likely coming from around the metal crush washer that sits behind the valve. When I installed the pcv valve I did it hand tight as I didn't have a torque spec for it. I removed the pcv valve and washer this evening and the washer doesn't appear to have any compression marks, so it likely wasn't on tight enough. Would anyone have a torque spec for an ap2 pcv valve ?, it would be greatly appreciated. Thanks for any reply on this.
Old 04-08-2012, 08:07 PM
ConanO'Brien's Avatar
my helms manual says 44N/m (33lb/ft).
Old 04-08-2012, 08:31 PM
zeroptzero's Avatar
Thanks very much for the quick reply, that helps me a lot . That explains why mine was leaking, I was afraid of stripping the threads on the valvecover so I had it set much lower than that. Much appreciated.
Sharps SSS
05-06-2014 07:58 AM
Calamari
04-27-2011 03:26 PM
zeroptzero
03-17-2010 04:00 PM
CTECHs2k
04-21-2009 07:18 AM
bluesaint
01-16-2006 05:48 PM
Quick Reply: Anyone With Ap2 Shop Manual - PCV Valve Torque Spec ?
