Ηλεκτρικά Θέματα Συζητηση για ηλεκτρικα θεματα που αφορουν ολο το αυτοκινητο, που συμπεριλαμβανουν ηχοσυστηματα και βελτιωσεις
Audio and Electronics
Old Sep 21, 2005 | 07:35 AM
fire fly's Avatar
nik2000 i have PM'ed you... check it out.
Im still working on mine... my litle accident set me back a little bit so im a little delayed... but soon ill be ready. Probably end of October.
Old Jan 24, 2006 | 01:55 PM
fire fly's Avatar
Well its been longer than expected... summer past and i was in no mood to get
my soldering iron out. Now that we are back into winter i rolled up my sleeves...
but instead of finishing off the sound system i decided to install an alarm.
I decided on the Viper 350HV. It has two remotes, door/trunk triggers, dual shock sensor, rolling code, proximity sensor, and all its functions are programable.
It retails normally for 250euro installed. Told the salesman that i would do the install myself and so we agreed on 150 euro!!!!!! (i think he was expecting me to fail and then go back and give him the extra 100 for the install)
Well it was harder than i thought...couldn't get all the wiring down even with the honda service manual! After searching on the net i found vipers/python/cliffords
retailers web site www.directechs.com which has all the diagrams, but you need a password... no prob enter google. Found a dealer password: c901mast
..... You didn't hear it from me!
Anyway once i got the diagram it was a piece of cake and that 100euro stayed in my pocket. If anybody tries this here are the wires you need to tap on the S2000. I also needed 3 relays ans 2 diodes (cost 2.5euro) to complete the job:
12volts white (x2) + ignition harness
Starter
blue/white + L of column, lt blue 24P plug
Ignition
black/yellow + ignition harness
Power Lock
pink/black 5wi keyless entry module
Power Unlock
yellow/green & pink/blue 5wi keyless entry module
Lock Motor
Unlock Motor
yellow/green 5wi keyless entry module
Disarm Defeat
Parking Lights+
red/black + keyless entry module
Parking Lights-
blue - headlight switch
Hazards same as turn signals
Turn Signal(L) green/red + steering column
Turn Signal
Old Jan 24, 2006 | 10:39 PM
energetic's Avatar
Nice one firefly!
You should do the instalation on our cars for less than
Old Jan 25, 2006 | 09:44 AM
fire fly's Avatar
sounds like we are getting into the "lets open a garage" discussion again
Old Jan 26, 2006 | 09:42 AM
vtec-man's Avatar
Firefly o viper sou apaitei Bit Writer gia ton programmatismo h oxi ? Exw access sto directechs edw kai poly kairo alla to mono pou me frenare gia thn topothetish tou Clifford mou RSX 3.5 htan to Bit Writer.
Epishs an xereis pou boroume na vroume vash gia monitor 7" panw sto tablo opws polla JDM, tha tolmousa na to kanw me polyestera alla den mou paei ka valw xyrafi sto tablw...
Old Jan 26, 2006 | 11:56 PM
fire fly's Avatar
To bit writter then eine aparetito. Boris na programatisis ta panta me kapious sinthiasmous tou valet switch kai to kleidh. (px - patima 3 fores valet, kleidi on off 2 fores klp). Apla to Bitwriter to xrisimopion sta sinergia gia efkolia.
Oso gia ton polyestera. Prota fiaxnis tin maketa tou tablo gia na kanies piramata kai meta kobis. Etsi tha eise sigouros oti to panel pou that fiaxis tha eine 100% perfect fit. Mono tote tha balis xirafi!
To kako me ton polyestera eine o xronos pou apeti.
Mia fora efiaxa gia ena Paseo pou eixa kai mou pire 3 mhnes. Ala to apotelsma eitan apistefto... kalitera apo mama.
kapou eixa di ena etimo ala de thimame pou... tha to psaxo kai tha se enimeroso.
Old Jan 27, 2006 | 07:05 AM
vtec-man's Avatar
Ama to vreis gia rixe ligo fws, psaxe, kane oti boreis... Psinomai karga gia 7" tv sto tablo! Alla thelw factory job!
Old Jan 30, 2006 | 05:48 AM
michail's Avatar
Mipos ine h MASTERGRADE h eteria?
Old Jan 31, 2006 | 01:57 AM
fire fly's Avatar
to vrikes!!
Old Jan 31, 2006 | 04:39 AM
drsoulis23's Avatar
mastergrade vaggelli!!!! mallon gia car pc se vlepo kai esena!!!pantos to montelo ths mastergrade einai gia lilliput 7 16/9 akrivos!!!
Blake9b
Dec 10, 2012 01:36 PM
trivium
Jul 1, 2007 06:33 PM
HeliFlyer
Oct 11, 2005 05:29 PM
xpander4
Dec 26, 2002 07:57 AM
