SVINI MONO TOU
Originally Posted by js266,Dec 31 2007, 01:42 PM
pitganon na einai petaloyda to idio mou eixe kanei kai mena piga honda tin katgarisane kai ola OK...KALI XRONIA
gt egw skeftomouna na valo tis js tin petalouda
Originally Posted by S2000_FUN,Dec 31 2007, 08:45 PM
Idle and hesitation problems can be caused by the following:
Loose throttle cable
Failed or failing MAP sensor
Failed or failing O2 / lambda sensor
Air leaks (on the vacuum side)
Blocked throttle lines
Dirty throttle butterfly
Blocked air filter
ISCV / AIC (idle speed control valve) misbehaving
Misfires are slightly different but can have some similar causes (more often than not its the MAP sensor if above 6000 rpm):
Damaged coil packs
Worn or damaged spark plugs
Damaged Crank Position Sensor
Corroded ECu wires - this has been found on a number of cars and isnt easy to detect or fix!
Failed or failing O2 or lambda sensor
Σε όλα αυτά να προσθέσουμε και την πολύ καλή ποιότητα βενζίνης που έχουν τα πρατήριά μας
Blocked air filter
Damaged coil packs
Το πιο πιθανο παντως ειναι το θεμα πεταλουδας, και ειναι ευκολο να γινει ο καθαρισμος χωρις να παει το αμαξι σε συνεργειο.
