Alabama S2000 Owners Club Areas including Huntsville, Birmingham, Florence, Decatur, Anniston, and Tuscaloosa
Tech ?
Old Mar 11, 2009 | 05:37 PM
Castanza_AP1's Avatar
Default Tech ?
What wire on the tps will give me a voltage reading of what its at
Old Mar 11, 2009 | 06:29 PM
wilburS2K's Avatar
Where at in the car are you looking to check voltage?
Old Mar 11, 2009 | 06:31 PM
i need a voltage reading for the tps.......commiting the ultimate sin of installing a zex kit and it has an internal WOT switch just needs a voltage signal from the tps to determine when its at WOT...it has 3 wires coming from it and dont want to mistake and tap the wrong wire and risk hurting it that way....yes i know n2o risks hurting it but so does a s/c or turbo....just cheaper and easier
Old Mar 11, 2009 | 06:35 PM
wilburS2K's Avatar
You trying to tap into it @ the ECM or at the throttle body?
Old Mar 11, 2009 | 06:36 PM
vjarnot's Avatar
If you're tapping in at the ECU, this will help:
https://www.s2ki.com/imagecatalog/imageview/19125/
Old Mar 11, 2009 | 06:39 PM
throttle body
Old Mar 11, 2009 | 06:41 PM
wilburS2K's Avatar
1 GRN/YEL (Circuit Z28
Old Mar 11, 2009 | 06:49 PM
thanks that what i needed but now thinking about it at the ems will give it a cleaner install
Old Mar 11, 2009 | 06:53 PM
wilburS2K's Avatar
Red/black wire should be coming out of the terminal posted by Vjarnot. Thats your TPS signal.
Old Mar 11, 2009 | 06:54 PM
Thanks
