Post Upgrade issues
One question that I have not seen asked yet.
The stuff in "mys2k and settings" that was saved in the "Note Pad" I think it was called...the area at the bottom
of the page where you could type whatever you wanted and save it...will that come back? I had a lot of useful notes
and things in there.
Thanks cthree and hope the upgrade finishes and we can get back to normal soon!
Are you sure its not caused by MySQL? (Is this local or external?)
Are you running a RAID setup?
Are you clustering or using a single server to serve a 1000+ users at one time?
Sometimes things don't show up in the OS because its limitation is caused by hardware configuration.
Check your I/O read/writes and CPU threads, Network throughput kbps and Disk activity m/s
Monitor this over an hour and revise your peaks and durations, make sure you log everything.
Joeh
Joeh
Everything which was MyS2K is now in your customizable profile which you can get to by clicking your name top right. I don't know where it is exactly, I haven't had time to look at the new site yet or play with any of the newer things.
Hey it doesn't work nearly as well as mys2ki however. Just shows you posts you posted in recently. Doesn't show threads you posted in with new replies or anything. Not organized by newest either. Unless I am missing something it is nowhere close to as good as mys2ki was. Have no way to keep track of subscribed topics and threads with new replies.
From: All up in your inner tubes. Whatcha gonna do sucka?
this is kind of a minor thing, but I've noticed on the "Change Profile Information" page under User CP, at the very bottom the state list stops at Pennsylvania.
