Brakes
Like boofster said, lip on the rotors or low pad material, it's time to change 'em.
You can get OEM replacement blanks for $35 a pop. Combine this with good pads (Carbotech XP10) and good ducting and you will not have a problem chewing through rotors/pads.
Timing/mileage has nothing to do with like the above posts. oem pads are good for street/spirited driving, I run the hp+ pads for the track/street as im too lazy to change them, work fine for both just squeak a bit on the street. because racecar!
