Arizona S2000 Owners Arizona S2000 Owners. s2000arizona.com
catastrophic failure of rear diff
Old Mar 27, 2006 | 02:58 PM
MR2S2K's Avatar
Default catastrophic failure of rear diff
Ok, after putting in a 6 puck race clutch, and launching a little harder then i usually do, the rear diff goes kur-plunk. There is a hole the size of a mandarin orange in the houseing. A fracture that runs fron the back of the housing to the front. The gears are broken and chewed up. Luckily the LSD is still in good shape!
On order is The comptec reinforced housing, 4.57R gears and all the little goodies the pumkin is made from.
The car is sittin at SOS now, so if anyone wants to see what a rear diff looks like after a 5k rmp clutch drop will do feel free to look. Chris at SOS was great, ordered everything in the morning and hopefully in a week or two, i will be doing more 5k rmp clutch drops sucessfully!
Old Mar 27, 2006 | 03:07 PM
AZDavid's Avatar
What did the car run before this happened? I am assuming you got a couple of runs in and this happened at Firebird.
Old Mar 27, 2006 | 05:18 PM
RobZ's Avatar
Just goes to show that the S was not intended to "launch" and drag race. It has a peaky powerplant, IRS and a 50/50 weight distribution for a reason...to carve up the corners.
Good luck with the new setup.
Old Mar 27, 2006 | 05:29 PM
MR2S2K's Avatar
if i got a quarter for everytime i see that, id own a ferrari by now. The car is a beautiful platform for everything. Drag racing just happens to be the part of the first leg race, track or any race. in order to get a head of your competition, you need to be able to put your power to the ground. When you need to turn thats a diffrent situation, then hopefuly your setup alows you to "carve" those turns as well.
Any one who modifies their car only to just "carve" the road is missing half the fun.
the car should be about balance, you should have enough power to "launch" and put your power to the ground as well as float through corners.. and be able to STOP as well.
Thanks for your support....
Old Mar 27, 2006 | 07:38 PM
Nonlinear Optics's Avatar
depends on where you drive. i ditched my other car in favor of the s2k because it does balance good straight line speed with corner carving abilities. improvements in BOTH areas will be coming
Old Mar 30, 2006 | 10:17 PM
KRAZYKOREAN's Avatar
Gold Member
S2000's suck my butthole
Old Mar 30, 2006 | 10:38 PM
ILL roller's Avatar
Definitely not true... If the car is stock, then a decent driver can give it a good launch without any problems. I've done numerous launches at 8-9000 rpm, with no problems.
The only reason he had problems is because like any other car, when you add power, something else has to give.
Old Mar 31, 2006 | 11:21 AM
l8brakr's Avatar
Launches at 8-9000 rpm
That's not a launch that is tire smoking mahem. I'd almost be willing to bet that probably has less shock on the driveline than a 6-7k launch because the tires instantly spin up with no hope of grip.
Old Mar 31, 2006 | 11:35 AM
can we not resort to anything poop related in at least one thread?
<checks around for splndid> ....
Old Mar 31, 2006 | 11:38 AM
do you mean actually side-stepping the clutch at 8-9k rpm, or feeding in the power aggressively with heavy slip ?
