Arizona S2000 Owners Arizona S2000 Owners. s2000arizona.com
Computer question
Old Jan 4, 2006 | 02:23 PM
Ragingazn's Avatar
Default Computer question
so I bought a new laptop so i have to give the other back to the owner... how do i transfer all the data onto my new laptop?
Do I just connect the laptops via cat-5 connections? or something abuot serial how does that work?
Joe
Old Jan 4, 2006 | 02:34 PM
AZDavid's Avatar
Actually, a USB Data Link Cable would be the easiest.
Something like this:
http://www.usb-ware.com/usb-2-usb-data-lin...cable-uc250.htm
You can pick one up at Frys. I expect it would just be drag and drop then. It will create a temporary drive in My Computer.
Old Jan 4, 2006 | 03:42 PM
WLAURENT's Avatar
You could network them together with a router and standard CAT5 cables or get a cross-over CAT5 cable to directly connect the two. But you have have some knowledge of how to setup the networking.
You could also burn them all to CD and use them to put them on your new laptop.
Probably the easiest ways is as outlined in David's post above. Unless of course you purchased an external USB 2.0 Hard Drive (as previously recommended - for preventing future data loss) and use it to copy everything from one PC to another.
Old Jan 4, 2006 | 04:46 PM
Ragingazn's Avatar
I plan on buying one, but that laptop set me back until a couple of paychecks later, besides my ex really wants her laptop back I'll do the data link thingy...
also Happy new year to you Will, i read the text message i sent out to everyone and um. well it didnt make sense to me lol
Joe
Old Jan 4, 2006 | 05:21 PM
asu_lee's Avatar
buy a crossover cable. PM me if you need help setting it up.
-Lee
Old Jan 4, 2006 | 05:29 PM
walkabt's Avatar
Speaking of cross over cables
Old Jan 4, 2006 | 05:44 PM
turbo_pwr's Avatar
cross over cable then you need to set-up a static IP address on both laptops to transfer the files.
Old Jan 4, 2006 | 05:53 PM
Ragingazn's Avatar
huh??? i got to the 'to' and the next word 'set-up' scared me
Old Jan 4, 2006 | 06:54 PM
WLAURENT's Avatar
Go to:
Control Panel
Network Connections
SELECT your Network Interface Connection - probably called "Local Area Connection" (double click)
Click Properties
Double Click "Internet Protocol TCP/IP"
In there:
Check "Use the following IP address"
IP Address: 192.168.0.2
Subnet: 255.255.255.0
Default Gateway: 192.168.0.1
Do the same on the other machine but use IP Address 192.168.0.3
If you have a proper crossover CAT5 cable (they are sold at Fry's for about $4) - you should be able to map a network drive from your new laptop. However, you will first need to share the drive you want to copy the data from on the ex's laptop.
If that does not work call Lee
Old Jan 5, 2006 | 05:38 AM
Doc's Avatar
Doc
Just call Lee anyway. He gets kinda lonely sometimes.
JJ
