Arizona S2000 Owners Arizona S2000 Owners. s2000arizona.com
Dyno Time
Old May 14, 2005 | 03:20 PM
JustinMcC's Avatar
Default Dyno Time
I wasn't really sure what to expect because I've seen stock numbers all over the place, but I'm happy with the results.
If I let the motor cool down a little more it'd probalby have put down a few more hp too, but I'm not too concerened about a hp here or there. I was just looking to get a good baseline number.
Edit: Oh yeah, it's a bone stock 2002 w/ just over 19k miles.
It was 96
Old May 14, 2005 | 04:36 PM
JustinMcC's Avatar
Also, here's a comparison of the Nissan 2.0L VVL engine vs the S2k.
The Nissan motor should be making about 7-10 more hp and torque, but I have a different header on there right now (trying to tune some stuff) and the secondary section is apparently choking the motor a little bit...
I've put down 178whp and ~143ft.lbs with the car in the past.
Old May 14, 2005 | 08:48 PM
RobZ's Avatar
Referring to the S dyno-would the powerband benefit from VTEC kicking in a bit earlier? Looks like it starts to flatten out then ramp up steeply as the big cam takes over. I am not a Honda expert so please correct me if I'm wrong.
Old May 14, 2005 | 09:19 PM
CypherAZ's Avatar
The flat spot is the VTEC dip, common on all VTEC engines. On my RSX you could smooth out the dip by lowering the vtec engagement, but I haven't seem similar results on s2k's w/ VTEC controllers.
Old May 16, 2005 | 08:33 AM
l8brakr's Avatar
I have my VAFC set to engage at 5700 and it definitely gets rid of the dip. I haven't looked at my dyno sheet in a while but I think it was a fairly smooth transition too. I don't think you would get any benefit from lowering it anymore for NA, it seems pretty good where it's at.
Old May 16, 2005 | 10:07 AM
JustinMcC's Avatar
Yeah, you can adjust it, as you can see on the SR20 motor there's not as much of a dip. The intake switch is seamless, and the exhaust cam switch there's a little bit of a jump. My cam switch controller on that car is a little more complex than a VAFC, so i didn't feel like messing with it for a couple hundred rpm at most. I may get a VAFC for the S2k, dunno yet. It's a lot of time and tuning for a few hp when the car's still stock...
Old May 20, 2005 | 10:14 PM
Bane's Avatar
Exactly.
A VAFC is almost worthless for a stock or nearly stock vehicle IMO... Honda probably had a whole team of engineers to determine the proper VTEC transition point in the S2000.
SC_Highlander
Feb 24, 2012 04:29 AM
Slithr
Oct 25, 2010 08:14 AM
gt30r
Jul 13, 2010 12:52 PM
pdexta
May 6, 2009 06:38 AM
Scorpion
Apr 16, 2006 05:58 AM
