power gains
Originally Posted by s2k_zonie,Sep 8 2006, 06:35 AM
The Comptech kit is now available with an aftercooler. I'm leery about the Vortech kit after Wil got stranded in Greer (oil leak from a brass fitting).
-Lee
Originally Posted by turbo_pwr,Sep 8 2006, 07:50 AM
I know it's available but it's not included in the base kit. Buying the kit is $ lot more then just getting the Vortech.
1 Post
Forget retail pricing, nobody pays retail on that stuff. Look up GB pricing on Comptech and Vortech and you'll see the difference. I use to sell this stuff for BP, you can get bigger breaks on Vortech then Comptech.
Really as long as you dont throw any codes than modifying really anthing on your car should be fine.... they just plug the computer in your little hole there and if everything checks out you're good to go....
1 Post
Correct. If you decide to go Turbo I only recommend going ems or even high boost supercharger I highly recommend only EMS. And naturally if you get a standalone your hole will not register anything at all.
If you want to do something that no one will notice then do the gears... you'll be quite a bit faster, but on the az freeways 80 might be up there in the rpms.
if you want to spend 5K... go with the vortech or the comptehc.. both are reliable kits.
Speaking of which.. T-Pwr whats your mod list like now?
Originally Posted by Gloffer,Sep 7 2006, 06:16 AM
Less than 10 HP. Biggest gain would probably be from the weight loss on getting rid of the stock exhaust. Stock exhaust weighs 50-55 lbs, while the heaviest single is ~20 lbs. and the lightest titanium single is ~12 lbs. Save your money for a supercharger if you really want to add power.
1 Post
Toda Spec A version 2 Cams
Toda Adjustable Cam Gears
Hayward Performance 48mm ITBs
Rick's Lightweight Pulleys
Hytech Header
BYS Straight Pipe
Amuse R1 Exhaust
AEM EMS tuned by HolyRollerDyno (gilbertq on s2ki)
She's still in the New England area undergoing tuning and testing.
Originally Posted by turbo_pwr,Sep 10 2006, 06:59 PM
2.1L Ballistic Motorsports prepped head (basically upgraded everything shop is owned by Twitzid on s2ki)
Hytech Header
BYS Straight Pipe
Amuse R1 Exhaust
Hytech Header
BYS Straight Pipe
Amuse R1 Exhaust
whats the inital dyno results?? past 230whp yet???
1 Post
I was at 235hp without the Ballistic head and cam gears. The compression ratio will be raised a little forgot what it is, I'll have to find out.
The lightweight pulleys don't really give you much if anything. The cams gave me a little but will be more worthwhile with the cam gears. This go around is the head work and cam gears with tuning. The 235 is without that stuff.
