Arizona S2000 Owners Arizona S2000 Owners. s2000arizona.com
Question on Amp
Old Oct 25, 2008 | 02:28 PM
watchdogd's Avatar
Default Question on Amp
I know this probably goes in the Electronics section but I'm asking here because it also relates to AZ weather.
I am considering getting an AMP and was wondering if anyone ever has problems with them overheating in the summer time and shutting off ?
Also, will a more powerful battery be required giving the summer heat or anytime for that matter ?
I'm leaning toward the JL audio or Fosgate both with about 300 Watts I believe.
Thanks,
Old Oct 25, 2008 | 03:35 PM
Steelerfan's Avatar
I run a 4 channel amp for my door and headrest speakers and a 2 channel amp for my sub. Both amps sit under my seats and have never over heated. I think if you ratchet the gain to the max may give you overheating issues but other than that I don't think you'll have a issue. Just a fyi... it all depends on what your driving compared to what's driving it. ( Speakers and Amps). I also have been using a standard battery with a stock alternator. Never had a issue.
Old Oct 25, 2008 | 03:48 PM
evan2's Avatar
Ive had a jl 500.1 in my s2000 for nearly 4 years and never had any issues. Ive driven it in Florida, England and now AZ.
Old Oct 25, 2008 | 04:09 PM
9KRDLIN's Avatar
get a fan cooled and decent sized amp and you will be perfectly fine. mine have overheated if I crank the tunes for about 10 minutes, but normal tune-age they work great. just make sure they are good amps with fans and you will be fine
Old Oct 25, 2008 | 04:33 PM
watchdogd's Avatar
Is yours under the seat or in the trunk ?
Old Oct 25, 2008 | 04:59 PM
evan2's Avatar
Mine are in the trunk
Old Oct 26, 2008 | 02:11 AM
Boofster's Avatar
I run the 500.1 in the spare tire spot. The insulation thing keeps dropping on it too. Never had any issues. Great amp
Old Oct 26, 2008 | 06:38 AM
9KRDLIN's Avatar
mine are in the trunk, i need to redo the amp rack as they are on top of each other and not side to side like they should be
Old Oct 26, 2008 | 04:52 PM
evan2's Avatar
Wade, I got the flat one that PAS2k makes and if you want pics I have one on my camera I can upload with my jl amps side by side
Old Oct 26, 2008 | 09:08 PM
watchdogd's Avatar
Hey if you have pics of an amp rack definitely upload them. I'm considering that vs hiding the amp.
I just wasnt sure if there was heat problems with the amp being in the trunk.
Thanks,
