Arizona S2000 Owners Arizona S2000 Owners. s2000arizona.com
Question on creeks
Old Sep 13, 2010 | 10:20 AM
-=Theoscion=-'s Avatar
Do you have wind noise with your top while you drive as well as the squeaks?
Don't know if it applies, but on my top, the latches that the top hooks into inevitably warped over time, causing the top to not latch as good as it should.
As a direct result of this, the top had some play, causing squeaks and a lot of wind noise, particularly at higher speed, like the freeway.
You can get the plates replaced, which will fix this problem, or you can ghetto fix it by putting something (somewhat thin) in the cradle of the hooks, which will tighten the clamp.
Hope that helps! :-)
Old Sep 13, 2010 | 11:48 AM
UGotsTaBTrippin's Avatar
I'm willing to bet the creaking is cause by wear on the locking mechanism. Put a small rubber grommet on the alignment pin & it should stop the creaking.
Old Sep 13, 2010 | 11:56 AM
9KRDLIN's Avatar
one of the ghetto fixes is to flip the latches (on the windsheild) from side to side. the other is to put aquarium air hose over the hook to add mass.
Old Sep 13, 2010 | 05:57 PM
watchdogd's Avatar
Thanks for the advice on the Lithium grease. Went out and got some. The creaks seem to be gone again so hopefully this will do the trick.
Anyone have that small hose, I'd like to put that one as well
tcho82
Jun 23, 2007 02:14 PM
BaNAnABoAt689
Oct 16, 2006 08:37 AM
anthonys2k
Dec 19, 2004 06:28 AM
danno1400i
Oct 28, 2003 10:21 AM
danno1400i
Oct 27, 2003 10:19 AM
