Arizona S2000 Owners Arizona S2000 Owners. s2000arizona.com
test pipe q's
Old Aug 19, 2008 | 02:10 PM
TheTownAbbott's Avatar
Default test pipe q's
I'm sure this is an old topic but... Is anyone running a stock exhaust with a test pipe. What size test pipe, 63mm? What are some of the problems passing emisions? Any check engine light issues? Thanks
Old Aug 19, 2008 | 02:14 PM
Nate4635's Avatar
I was running that setup for about 7 months until recent when i got an exhaust...
You will notice a smell, slightly raspier noise and no CEL if you do a fix. (Search Mechanical O2 Fix, or Test Pipe CEL Fix).
In all reality, you SHOULD be able to pass since with OBDII vehicles they just scan your ECU and if you dont have any CEL's, you are good. I think soemwhere its on the books that they do a visual, but....never have for me. I've always just put my cat back on incase they do. Plus if anyone working there has a good nose, they will smell it.
Running a 60mm T1r
Old Aug 19, 2008 | 02:15 PM
9KRDLIN's Avatar
get the CEL fix and you should pass no problem... i believe stock sizing on piping is 62mm but not sure (before the Y)
Old Aug 19, 2008 | 03:07 PM
Thanks for all the info. I think in the long run it's just best to go with an exhaust, I'll let you know which route I end up at, thanks again
Old Aug 19, 2008 | 09:11 PM
Mercuri's Avatar
im considering doing the same thing, ive been looking at the berks test pipe.
Jesman69
Mar 4, 2015 05:03 PM
Logan90
Oct 9, 2010 04:43 PM
JB3EZY
Feb 12, 2010 10:33 PM
JoeyBalls
Feb 17, 2008 03:44 PM
Saud2k
Apr 14, 2004 06:28 PM
