NEED HELP! clutch/tranny issues
long story short: had the car up on jack stands for a few days, changed my tranny fluid, and now the clutch won't engage. thinking i need to bleed it but i've never had any experience doing so. also, i think i must have broken some linkage trying to put it into reverse because my shifter now makes a complete square and i've got a box full of neutrals... any advice would be great!
i'm trying to get it fixed as soon as possible to make it to the bmt!
Hey man hit me up if you want to ask questions. But some stuff to try make sure clutch fork is on throw out bearing and the slave cylinder ball is on the fork. To bleed it you really need two people: first undo the bleeder valve on clutch then have someone press clutch to floor and hold. Tighten bleeder and have them pull clutch up. Repeat this until fluid streams out of slave cylinder make sure you top of master cylinder during this process. As for the "box" issue if you have first through fourth and reverse. Then try to pull up on your shifter it may not be greased and is depressed which will lock you out of 5th and 6th
maxLikelihood
Jul 8, 2016 05:37 PM
