Asia S2000 Owners English speaking owners from Asia. Including Hong Kong, China, Japan, Singapore, Malaysia, Taiwan.
Help translating instructions please!
Old May 20, 2011 | 09:55 PM
Boofster's Avatar
Default Help translating instructions please!
Can someone please translate these?
Usually they are self-explanatory but I really have no idea what's going on in the last two images.
Would be nice to know all the notes about this to do it correctly.
Thank you!
Old May 24, 2011 | 05:26 PM
Mr2000's Avatar
Now maybe I'm wrong...
From left to right top to bottom:
If you adjust this doohickey just right, your car will float
Now because wheels aren't very efficient at flight you simply remove the wheels, and this bolt, then replace with a flux capacitor, and replace the bolt
The end results being the black part of the bar graph at the bottom
Yay!
Good luck with the translation my friend
Old May 31, 2012 | 04:35 PM
Berlina.07.AP2's Avatar
Rough translation...
5) If the collar is too-large and doesn't fit then the outside of the collar needs to be ground-down with a 'belt-sander'.
6) If the hole in the upper sub-frame appears too narrow, ensure the position of the collar is correct and ensure there is no weld-splatter interfering with the fit. If weld splatter is present, grind down with hand grinding tool(e.g. Leutor) as shown.
Does that make sense?
vtecmonster
May 8, 2020 07:45 AM
ceejs2k
Jan 5, 2018 08:01 AM
Dembo
Car Talk - Non S2000
Aug 1, 2015 11:53 AM
s2000Junky
Jan 31, 2013 12:17 PM
AustinS2k2003
Oct 19, 2004 03:51 AM
