JDM Nav system placement
Hi Japan,
I'm about to retrofit the JDM Nav system bezel in an Aus RHD dash. I believe it is meant to be installed in a dash with a pre-cut hole but I am planning to cut my original dash.
I have it pretty well figured out but I would appreciate some accurate measurements.
I am interested in the distance in mm between the blue lines. The pair on the right are the most important as they will allow me to accurately work out the horizontal placement.
BTW, what you're looking at is a fibreglass mould taken form the Nav bezle in order to find it position by fitment. It's reasonable accurate but I like to measure twice, then measure again, then double check, then cut (usually my hand) once.
Any help you can give would be greatly appreciated.
