Aus & NZ Off Topic For all non S2000 related topics
I need a Wireless access point
Old Dec 9, 2008 | 06:34 PM
Austblue's Avatar
Default I need a Wireless access point
Hey guys I've just moved in to a house with a LAN set up and wanted to make it wireless for my laptop and possibly for my xbox. Can anyone suggest a cheap access point with a link if possible? It seems most of them are $$$ and way overkill for what I need.
BTW its a 2 storey brick house and not big enough to worry about range.
Also the reason I mentioned the xbox is I read briefly that you can use non-oem wireless client receivers on them does anyone know is that the way to go or just get the OEM wireless receiver?
Cheers.
Old Dec 9, 2008 | 06:39 PM
AusS2000's Avatar
Don't know about the Xbox but have some experience with access points.
Firstly, look for one that is just an access point. I picked up a Belkin Range Extender for $12. It's meant to be a range extender but can be configured in AP mode. It's a 802.11g but unless your internet connection is incredibly fast there's not much point in going to N.
Old Dec 9, 2008 | 06:42 PM
Ap1.M3k's Avatar
id go with net gear
i must admit that's smart though, using an expander ...
Old Dec 9, 2008 | 07:44 PM
Austblue's Avatar
Where'd you get that Aus? Ebay has no cheapies
Old Dec 9, 2008 | 08:32 PM
x2k's Avatar
x2k
Net gear are pretty reliable, I had mine for 8 years and it still running awesome.
Old Dec 9, 2008 | 08:52 PM
AusS2000's Avatar
Not a fan of Netgear. Have had two of their wifi routers and both have died on me.
Old Dec 9, 2008 | 08:57 PM
wilch's Avatar
I'd recommend going with the Microsoft 360 Wireless adapter for your xbox360. It's the simplest to set up, will work immediately, and will continue to work without any hassle.
Just be wary of wireless and lag. If you game with your 360 over live, then you might notice issues. But if you're using it to stream divx's and avi's from your PC over the air then it should work no problems.
Old Dec 9, 2008 | 11:54 PM
STAIN's Avatar
Were using a linksys access point my ps3 and the access point are opposite ends of the house gyprock walls, the ps3 gets 65% signal strength.
works fine for online gaming...
