Accidentally shorted battery
I recently had to charge my flat battery ( not using car very much at the moment) and when I attached the neg lead back to the battery (with pos obviously already connected) I accidently (and clumsily) touched the ratchet used to tighten the nut between the neg and pos terminals of the battery resulting in big spark and me jumping quite high.
The car has been used since then and everything seems normal, but my question is could there have been damage to the electrics and/or the battery?
Many thanks.
Many thanks.
Many thanks.
Many thanks.
electrics have fuses, so they wouldve blown first. battery cells could get damaged but unlikely, only way is to get a tester or if it doesnt hold charge. letting the battery discharge a few times (i.e. run flat) damages the cell... i learnt this the hard way... well... $180 way.
Many thanks.
Many thanks.
it'd be a bad electrical system if they fried their ECUs. As said, the current goes through the fuse block first and would blow the 100amp main fuse.
if the car runs fine, don't worry about it.
Shortest current path was through the ratchet, the current would never have passed through any fuses.
Two things can happen at the very extremes i.e. high amperage battery and thin ratchet, you can melt the ratchet from heat caused by the current passing through it. The battery may explode as the quick discharge of the battery will also cause it to heat up.
So if you're not dead then no damage has occured, if you car runs which you have stated it does, then the ecu hasnt been damaged.
Edit* the extreme situation from above is not possible with a standard car battery and a ratchet that would actually work as a tool, incase that wasn't clear.
/thread
/thread
/thread
/thread
I am just curious to know how you could actually fry your ECU from doing this? If the shortest path is through the ratchet, doesn't that mean it's not possible to fry the computer?
pretty much is impossible from the incident you had.
Majority of the sensors that are wired to the ECU would be 5V inputs, if you had shorted your battery (12V) to a sensor then you could blow that sensor input. Depending on the design of the circuitry of the board will determine how much damage can occur.
