License Plate Bracket
Guys, this is the story.
I removed the license plates to wax the bumpers, but when I wanted to screw the front plates back on, I noticed the driver side bracket had came off and was barely visible from the 2 holes in the bumper. I tried to fish it out but only made it drop into the bumper.
Currently the front plate is being held up by 1 screw. Anyone has any idea how to screw the other one in, when there's no thread in the hole in the bumper? Removing the bumper is the last thing I have in mind at the moment.
Thanks!
Thanks!
haha same happened to me, I managed to fish mine up to the bumper hole again. If you manage to retrieve it have the right sized screw ready to grip on to it. Otherwise only way is to remove the front bar. Maybe you can relocate the license plate now? bumper plugs can get off E Bay, a bit of 3m double sided tape and your good.
glw it.
glw it.
haha good to know I am not the only one! I was reading on another thread where you relocated your plates, how did you fabricate your bracket to attach to the grille?
The dealer plate bracket, if you have this still, the back bracket can be used and adjusted to center bolt off mid grill where there is the thread. This then bolts up center of your plate, and zip ties finish off on the corners, I also put some sticky back rubber at the back of the plate that molds into horizontal bar of the grill.
pics to make easier...don't have a pic of the dealer bracket.
Don't be scared to take your bumper of if you have to, it's not as hard as you may think.
As for the plate relocation, I just used a couple of L brackets I got from the hardware store and bolted them to the bottom of the grill.
Obviously I had the holes left by the original plate plastic welded and the whole bumper resprayed. But I think you can buy colored plugs to fill the holes, I think I've seen them on one of the other posts around here.
[/img]
[/img]
[/img]
[/img]
Thanks boys, I like the look of the plates in the middle. Problem is mine is not slimline plates like what you both have I tried positioning the plate in the middle but car looks like a kid who just stuffed his mouth full of food. What you reckon? Will it block air flow to the radiator? Air Intake should be ok since its at the side.
On the race track having the number plate positioned in the grill raises my temps considerably on the temp guage, I have both a koyo Rad and oilcooler and both temps increase alot. I remove it on the track. Just a thought if you do alot of spirited driving or track days.
