I2ice's build thread.
the condition of the bbs's before getting them refinished and reverse mounted weren't that great. and i had always planned to reverse mount them because it shows more of the lip and less of the face which is what I wanted. I am running 215/40 on the 9" fronts and 235/40 on the 10" rears, the tires are the hankook ventus v12's are a little beefier than the average falken or kuhmo etc.
Im finally done with school for the semester! so back to working on the s2000, I put on the driver side fender and pull off the upper control arms to get the adjustable ballpoints pressed in.
another update
Got the balljoints pressed in
and the result of the rear after
for the front i need to flare the fender a bit, and dial out less negative camber. more picture of that later.
got the car on the street! still alot more work to do, just wanted to drive the car around and test for rubbing and what not. the car is DIRTY as shit! the front driver side fender still needs to be painted, i still need to dial in the rear camber/toe and get it aligned, also going to try and get less negative camber in the front.
