Journey into the S
Journey into the S
10-03-2014
Bought my car BADASS 06 AP2 GPW
Came with Koni Yellow Rears in the trunk
10-05-2014
Maintenance
- Fixed loose Power Outlet
Spent more damn time trying to get this Napoleon Dynamite pen out of the nook next the the passenger seat rail nearest to console.
Broadway Mirror 9 inch Convex
10-06-2014
OEM OIL FILTER + CRUSH WASHER
Swift Spec R Springs
10-07-2014
MAINTENANCE
117,444 miles
- Adjusted Valves and Replace Spark Plugs
- Replaced Valve Cover Gasket and Grommets
Billman Generation-X lifetime modified TCT
Koni Front Shocks
Castrol Edge Plus Titanium 5w-30
Castrol/Syntrax Limited Slip Gear Oil SAW 75w-90
Rain X All Season Washer Fluid
Chevron Techron Fuel Additive
OES GENUINE Honda M/T FLUID - 3 QTY
OES GENUINE Honda COOLANT/ANTIFREEZE - 2 QTY
OEM Honda Cabin Filter
Sixity Bracketless Windshield Wiper Blade
I am pretty much still waiting on parts to arrive in the mail. Parts I take a picture of will have already been in my possession so everything else is in transit. Patience grasshopper, patience.
One of my dash bulbs is out too, no time to research that today.
10-08-2014
Maintenance
117,450
- Resurfaced front rotors due to (slap job by P.O. - Putting New Pads on without Resurfacing Rotors) Symptom was annoying embarrassing squeak coming to a stop anywhere.
I thank my friend/mechanic... let's call him RICEMASTER
I took the opportunity to take off the front license plate bracket and go ahead and plug the holes. The right side that accepts screws almost fell in but luckily it was saved. Planned to order the plug but luckily they were in the boot.
As the S sits after work Gotta get some crush washers to do my Differential and M/T (when it arrives).
10-09-2014
Muahahahahaha was told that that the Honda Coolant I ordered from carparts.com was cancelled and refunded. I don't know how the numbers work but I scored 3 bottles of Honda M/T Fluid for $13 and some change. WHICH BY THE WAY I AM IMPRESSED BECAUSE IT ARRIVED TODAY AND THEY WERE IN ILLINOIS!
Bought one Quart of Castrol Edge with Titanium 5w-30 just in case because I read online that some people had to use more to get to the full line.
Went down to the local Acura store and picked up Transmission crush washers for Fill/Drain and Acura Type 2 Coolant (SAMETHING AS HONDA).
Also went ahead and bought myself a 301 Mechanics Tool Kit from Harbor Freight. I got tired of the smaller versions that had a really bad case (I am sure this one is bad, but it holds things waaaay more securely because of the trays). FYI it fits perfectly in the space in the middle of the trunk. if you remove the tools I am sure you could fit even more.
http://www.harborfreight.com/profess...kit-45951.html
Copped it for about $173.xx using a 20% Coupon and got a bag of free 8" Ties with it
Broadway 240mm Mirror (which is approximately 9.44882 inches) came in today as well. It is the Convex Version.
10-10-2014
Maintenance
117,520
- Replaced TCT with Billman250's GenX TCT
- Cabin Air Filter Replaced
Today a vast majority of parts arrived shown below! Billman250 GenX TCT, Honda Cabin Air Filter, and Swift Spec R Springs. I also went ahead and bought a Gear Fluid Pump tool to help me get M/T Fluid into the transmission. It fits Quart Bottle Thread so its convenient.
Link to it is here:
http://www.harborfreight.com/gear-oi...ump-61746.html
Bought it with yet another %20 off and got a free magnetic bolt/part holder, and 12 pack of microfiber cloths.
OLD TCT
New GenX TCT
Old vs New Cabin Air Filter
Showcasing my Harbor Freight 301 Mechanic Tool Set (F*cking handle broke. Its okay I don't plan on carry it long distances ever)
There is a third tray under that. I didn't have to get into that one to do the GenX TCT replacement.
10-05-2014
Maintenance
10-06-2014
10-07-2014
MAINTENANCE
117,444 miles
Koni Front Shocks
10-08-2014
Maintenance
117,450
10-09-2014
10-10-2014
Maintenance
117,520
Link to it is here:
OLD TCT
New GenX TCT
FYI guys, I am just editing the first post each time I update it because it bothers me when comments interrupt the thread. If there is another way to solve that issue please let me know!
Hey Themikewoo just updated for today. Next up tomorrow is Engine Oil, M/T Fluid, and Differential Fluid. I will be replacing with Castrol Edge with Titanium 5w-30 (OEM Honda Filter and New Crush Washer), Honda MTF, and Castrol Syntrax LS 75w-90. Probably will also do the Rain X Fluid.
Continuation...
So it forced an image limit on me so I have to start over
10-11-2014
Maintenance
117,557
- Changed Oil and Filter using Castrol Edge w/ Titanium 5w-30 and OEM Honda Oil Filter and Crush Washer
- Changed Manual Transmission Fluid with Honda M/T and crush washers for drain/fill.
- Changed Differential Fluid with Castrol Syntrax LS 75w-90 and crush washers for drain/fill.
Differential Magnetic Drain Bolt was Dirty with Shavings (I left my phone in the car while it was on the lift and had my friend take a picture of it. Sorry for the lack of clarity)
Sixity Wiper Blades - ~ $13 for the pair
I wish these arrived yesterday cause it was pouring. I will give a review of them once they have been put under some real world testing.
Next up to do is wait for the Crankshaft Holder ORING to solve that weep and suspension this week. I can safely push the car now mechanically.
10-12-2014
Maintenance
117,672
- Replaced Windshield Wiper Blades
- Put in Rain X Allseason Fluid (Orange Fluid = bad idea lol)
- Filled up gas and put a whole bottle of Techron Fuel Treatment
Purchased Goodyear Gatorback Serpentine Belt 4060578
Initial impression of the Sixity Wiper blades for a mere $13 is that there is no streak and VERY QUIET! Granted they are brand new so we shall see later down the line!
10-13-2014
Today we have OOOOO LOOKIE HERE THE FRONTS! *Reminder* I already had rears because they came in the trunk when I bought the car and I already received my Swift Spec R Springs in the mail.
When will they be installed?! Your guess is as good as mine. Hopefully sometime this week!
10-15-2014
117,777
- Replaced Crankshaft Holder O-Ring (Common Oil Weep Issue and Torqued to 36 lb/ft)
10-18-2014
Maintenance
117,933
- Changed Idle Pulley Bearing w/ TIMKEN 203FF
I was changing my belt and noticed the sound and little crunchy noise for the pulley. I replaced the bearing, but ended up putting the Micro V Gates belt back on cause its still good.
Tips: Use a 27mm socket to beat the old one out. (Can't reuse it so you better have the right replacement) Use a 29mm socket to put the new one in with a hammer or mallet. Make sure you re-position the socket after each hit. There is a good DIY on how to take off the idle pulley and such. Have a great day my friends
10-11-2014
Maintenance
117,557
10-12-2014
Maintenance
117,672
10-13-2014
10-15-2014
117,777
10-18-2014
Maintenance
117,933
