Automotive builds Got an automotive build you want to want to document? Post it here!
View Poll Results: What color should i go with
Rosso Corsa (Glasurit FER 300/9)
4.35%
Rosso Corsa (Glasurit FER 300/12)
17.39%
Rosso Scuderia (PPG Fer. 323)
34.78%
Nuovo Rosso Formula 1 (PPG)
43.48%
Voters: 23. You may not vote on this poll
NFR wide body
Old 06-14-2018, 03:51 PM
  #311
c_me_go's Avatar
Old 06-15-2018, 07:33 AM
  #312
jaor.s2k's Avatar
The new valve cover color looks much better
Old 06-15-2018, 09:45 PM
  #313
c_me_go's Avatar
its the same valve cover as before.. actually I would like some input on who ever is still reading this thead. This is the lasted mock up.. so my issue is not sure where to go from here.. was thinking stay with the purple and black and do the valve cover a gun metal.. or going with a red black and gun metal valve cover.. just not sure.. any thoughts??
Old 06-16-2018, 09:05 AM
  #314
sirbikealot7's Avatar
Be sure to loctite the countersunk phillips screw in the wheel stop on that TB and be prepared to drill an extra hole to put the spring under some additional tension at full closed. I almost had a catastrophic failure on track due to that damn thing.
Old 06-16-2018, 10:08 AM
  #315
c_me_go's Avatar
thanks for the heads up.. will pass that along.. we are also changing the accelerator line and making it shorter.
Old 06-19-2018, 04:06 PM
  #316
c_me_go's Avatar
Making good progress,, clutch in along with AP2 tranny.. and engine and turbo kit in as mock up...
Old 06-22-2018, 05:49 PM
  #317
c_me_go's Avatar
Old 07-22-2018, 04:09 PM
  #318
c_me_go's Avatar
Making some headway.. got most of the power coating done.. tucked the brake lines.. and just got a few more issues to work out.. then off to the dyno
Old 09-30-2018, 01:42 AM
  #319
c_me_go's Avatar
In the finishing part now , next step is tunning ...
Old 09-30-2018, 01:43 AM
  #320
c_me_go's Avatar
Quick Reply: NFR wide body
