California - Bay Area S2000 Owners California Bay Area S2000 Owners Group
anyone got a DTC Scanner
Old 11-12-2006, 11:29 AM
WashabiS2K's Avatar
Default anyone got a DTC Scanner
hey guys, well as many of you know, i don't have any power steering for some weird reason that i do not know of... so does anyone out there have a DTC Scanner that i can use to scan my car? or is there another kind of scanner i can use to find out what's wrong with my power steering? anyway.. i wanna try to fix this thing out sooo.. if anyone can help , it'd be greatly appreciated.
Old 11-12-2006, 01:26 PM
itS2Krazy's Avatar
is there a check engine light on? im not sure a DTC scanner will give a code for the EPS
i have a code reader BTW.
Old 11-12-2006, 02:11 PM
lilken's Avatar
you dont have power steering?!? i drove an fc without power steering and that was tough taking corners for the first time was hella scary
Old 11-12-2006, 02:23 PM
WashabiS2K's Avatar
im not sure if my CEL is on.. probably is, *shrug.. i havent driven my S in about 2 weeks or so now. i've started it up though, just to check if the EPS would come back on.. took it out once around the block but no luck getting it to come back to life. in the s2000 book, it says you can use a DTC scanner to find out what is wrong with the EPS so im not sure.
Old 11-12-2006, 02:28 PM
itS2Krazy's Avatar
if there is a symbol for the check engine light. that means you have a CEL..
also let me ask you this. did you swap out the headlights? if you did, did you unplug something that could have caused this EPS problem? or did it happen before you swapped out the lights? maybe a harness is unplugged.
Old 11-12-2006, 02:32 PM
mina's Avatar
Wink
well duh
j/k
I bet you could figure it out right quick, Joey. Make a house call!
Old 11-12-2006, 03:04 PM
WashabiS2K's Avatar
lolz joey, i aint that slow.. i am not sure if there is a cel at the moment (havent turned on the car in a while) but the EPS indicator light is on. also, the EPS problem first started acting up the night i bent my rims.. but it only turned off for a second. i pulled over, turned the car off, and turned it back on and the power steering was back to normal.. not this time, however. the EPS is off, and remains off.
Old 11-12-2006, 06:16 PM
itS2Krazy's Avatar
you can bring it by my shop when you have a chance. my address is 2300 westborough blvd. south san francisco. CA 94080
Old 11-12-2006, 08:58 PM
WashabiS2K's Avatar
will do. (after i get my headlights installed, lol)
Old 11-12-2006, 10:37 PM
itS2Krazy's Avatar
oh btw, i didnt mean to offend you. i was just saying. cause maybe it was related?
Quick Reply: anyone got a DTC Scanner
