Cam sensor
Does anyone have a cam sensor I could borrow? I believe one of mine is bad but would like to test it first by swapping in a known good one. I am located in south San Jose. Thank you
Like I suggested earlier, see if you can find the pins for the cam sensor at the ECU connector and test from there. If it looks good, I would suspect the ECU itself as a culprit. At that point, you need to determine whether it's software or hardware. If there's a bad signal at the wiring harness then you know you have a wiring issue somewhere upstream. Good luck!
BuggyofMildDiscomfort
Jun 9, 2014 10:04 AM
