California - Bay Area S2000 Owners California Bay Area S2000 Owners Group
Cam sensor
Old Apr 24, 2017 | 06:41 AM
S_DosMil's Avatar
Default Cam sensor
Does anyone have a cam sensor I could borrow? I believe one of mine is bad but would like to test it first by swapping in a known good one. I am located in south San Jose. Thank you
Old Apr 25, 2017 | 11:18 AM
S_DosMil's Avatar
Anyone?
Old Apr 27, 2017 | 03:13 PM
S_DosMil's Avatar
Thank you leonV for letting be borrow a cam sensor to test my issue. Much appreciated. Btw your car looks in pristine condition.
Old Apr 27, 2017 | 04:28 PM
LeonV's Avatar
Thanks man, good meeting you! Yours looked like a serious build. Let me know if you need anything else.
Like I suggested earlier, see if you can find the pins for the cam sensor at the ECU connector and test from there. If it looks good, I would suspect the ECU itself as a culprit. At that point, you need to determine whether it's software or hardware. If there's a bad signal at the wiring harness then you know you have a wiring issue somewhere upstream. Good luck!
Old May 4, 2017 | 03:21 PM
S_DosMil's Avatar
Does anybody know off hand if you disconnect cam sensor A(intake) if the car will die on the stock ecu.
Pacman123
Oct 5, 2016 06:01 PM
BuggyofMildDiscomfort
Jun 9, 2014 10:04 AM
Rugby_Guy
Mar 11, 2014 12:18 PM
robertjr314
Jun 2, 2010 06:34 PM
ack5252
Feb 19, 2008 12:50 PM
