California - Bay Area S2000 Owners California Bay Area S2000 Owners Group
DIY Second Power Source
Old Jun 22, 2011 | 09:12 AM
Voodoo_S2K's Avatar
Originally Posted by na3j nitsuj
Just tap into the fuse box by your kick panel. That's how I hardwired my radar detector. No splicing needed..
I have all my addon electronic stuff wired directly to the fuse panel. I don't piggy back on any of the existing circuits. There are available switched and non-switched locations you can use.
Old Jun 22, 2011 | 10:26 AM
na3j nitsuj's Avatar
I didn't really check the other ones. I figured it would be easier for me.
Old Jun 22, 2011 | 10:53 AM
Offtrack's Avatar
I do the same. Why would you cut/splice/tap into an existing circuit when Honda has provided locations in the fuse box for this purpose?
Old Jun 22, 2011 | 01:13 PM
macr88's Avatar
Originally Posted by thomsbrain
You can go to the fuse box but you still need to ground, and at least on my car, there's no human way possible to reach that sacred mythical ground bolt above the kick panel without hiring a team of super intelligent rats, training them for years to ground wires for cheese, and then setting them free in the cabin.
I grounded my stuff there and also used the free spare connections on the fuse box. Make sure and install the fuse closest to the power source and not the powered device. (closest to the fuse box) You don't want the wire rubbing on something grounded and cause a fire because you installed the fuse on the wrong end of the circuit.
Old Jun 23, 2011 | 08:36 PM
rob-2's Avatar
Debating about buying a the same outlet we have, parts 1-4, and putting it under the dash by the passenger. I'd fuse it, but I'm not sure what fuse yet to buy. I'd run the power cord behind the radio out to the fuse panel on the drivers side.
Thoughts?
I originally was going to go with 1-2 extra sources plus USB but I think it would be clean enough with a nice place for the GPS.
Old Jun 24, 2011 | 08:12 AM
Offtrack's Avatar
Typically 10 amps should be fine......No more than 15 for sure. If you are only using for a phone, gps, etc... go with 10. If your going to plug in a dc/ac inverter go with 15 (per circuit).
For usb charging requirements I use these.... http://www.parts-express.com/pe/show...number=139-006
yourboysoap
Apr 22, 2022 05:19 PM
Car Analogy
Jun 9, 2021 01:38 PM
Lainey
May 19, 2016 06:34 AM
mozmajor
Feb 7, 2015 12:25 PM
captainbk
Dec 3, 2006 07:00 AM
