California - Bay Area S2000 Owners California Bay Area S2000 Owners Group
Maintance require!!!
Old Jul 26, 2002 | 12:41 PM
GundamZ's Avatar
Default Maintance require!!!
I was wondering since Honda doesn't require my first maintance till 7500miles. Do I need to do anything till that time. I notice my dip stick (when car is cold) is only 3 diamonds above the E line. Should I take it for an oil change? If I do, what kinda of oil should I ask them to put? I most likely will buy the oil and take a to a shop to have them change it.
Thanks,
Old Jul 26, 2002 | 12:55 PM
pll's Avatar
pll
Get some 10W30 oil and top off the oil.
Old Jul 27, 2002 | 08:45 AM
yu888's Avatar
just top it off with non-sythetic 10-30. if the oil is really dirty, you may consider a change at 5-6k or so if you are really concerned. otherwise, just keep the oil level full. the car is known for burning some oil in the first few thousand miles, so check often.
Old Aug 6, 2002 | 08:44 PM
racer chick's Avatar
NOOOOOOOOOOO!!! NO synthetic oil!!!!!! if your engine isn't broken in yet, synthetic oil will prevent the rings from sealing!!! put regular castrol gtx 10w40.. with honda oil filter of course. oil changes should be every 3,000 miles. questions? pm me
Old Aug 6, 2002 | 08:45 PM
it takes 5 quarts of oil... by the way.
Old Aug 6, 2002 | 08:48 PM
fyi: if you drive hard, engine breaks in at 5k mi. if you drive gently, it breaks in at 7k mi
Old Aug 7, 2002 | 12:17 AM
pellisS2k's Avatar
if you don't want to change the oil, you might consider just changing the filter.. if you do it in the morning, when the car is cold and everything has had plenty of time to drain, it can be done with a minimum of spillage.
Saki GT
May 13, 2007 02:13 PM
SLAPMYFRO
Jan 22, 2003 03:40 PM
Steve2K
Oct 30, 2002 03:32 PM
SECRET AP1
Aug 8, 2002 07:35 PM
chroot
Mar 30, 2002 01:15 PM
