California - Southern California S2000 Owners Southern California S2000 Owners
clutch/transmission problem
Old 08-22-2010, 11:44 PM
AlexS2200's Avatar
Location: 13851 A Better Way #11D, Garden Grove, CA 92843
Sure no prob. Bring it buy
Old 08-23-2010, 12:56 AM
S2Kmonkee's Avatar
i think i forgot to mention that the car has no problem going into gear while the car is off.
Old 08-24-2010, 01:32 AM
1FastS2k's Avatar
This happened to me. I was merging onto the freeway and I heard a pop then pedal went to the floor. I lifted the pedal with my foot and the pedal was stuck in the upright position. With all of my strength I could not push the pedal down. I was only a couple miles from the house so I rolled through some stop signs and made my way home rev matching the shifts. Turns out my T/O bearing exploded. When we pulled the trans, ball bearings fell out.
Old 08-24-2010, 07:38 AM
ssjlaosy's Avatar
Originally Posted by S2Kmonkee,Aug 22 2010, 11:30 PM
im planning to do this at home just for the learning experience. I mean i would truly appreciate it if you would diagnose it for me.
hey let me know im plan on switching my clutch soon too getting tired of my stage 3....
Old 08-24-2010, 07:48 AM
05TurboS2k's Avatar
So much incorrect info in here..... sigh.
Old 08-24-2010, 07:49 AM
05TurboS2k's Avatar
[QUOTE=AlexS2200,Aug 22 2010, 11:25 PM] I'm pretty positive it is the clutch.
Old 08-24-2010, 07:59 AM
S2Kmonkee's Avatar
Originally Posted by 05TurboS2k,Aug 24 2010, 07:49 AM
This is about the most sensible guess in here.... along with the other post about a T/O bearing etc. My best guess is of course something physical blocking the pressure plate etc.
OR.... its possible even the linkage on the slave could be jammed up somehow though I find it rather unlikely.
yesterday, i took off the slave cylinder and the clutch depress fine. so it really comes out to something in the transmission. Ill take pictures this friday. Anybody has any idea how much a throw out bearing would run me? if it's the throw out bearing that broke?
Old 08-24-2010, 10:47 AM
1FastS2k's Avatar
I was just stating my personal experience which sounded a lot like the OP's. Everything else on my clutch was fine, just the T/O bearing was destroyed. If you are in there replacing the bearing, you might as well do the entire clutch while you are at it.
Old 08-24-2010, 11:20 AM
blueap2's Avatar
My opinion on this is that one of the sections on the clutch disk broke off like someone previously stated and got engaged between the springs on the disk. I've done two s2000 clutch swaps in which that was the case and when attempting to put the car in gear it was almost impossible due to an extremely stiff clutch pedal.
Old 08-24-2010, 12:36 PM
S2Kmonkee's Avatar
i think he meant that yours made sense also. Im hoping it's not the TO bearing as i called honda and they wanted 150 for it. Hope blueap2 is right that it's the disk that broke. Also ill be changing the clutch to since the tranny is getting swapped.
Quick Reply: clutch/transmission problem
