Automatic transmission problem (daily driver)...
Old Nov 17, 2005 | 02:55 PM
Luke530's Avatar
Default Automatic transmission problem (daily driver)...
it's an '02 grand cherokee I6 4.0
I think it's the torque converter... but i'm not sure.
Scenario: I'm standing still at a stop sign, I let go of the brake and apply the gas to normally accelerate away, the stall seems to be higher than normal like it's having a tough time moving and then finally i feel a catch and i go along my way...
it also has a werid time find a gear sometimes (takes a little while or shifts from 1 to 2 back to 1 for a second and hops back to 2) when i accelerate having the pedal pressed in the same exact spot the entire time.
same thing when turning and accelerating, i give it gas, the rpm climbs a little (just under 2k) on a 5.5k redline, then it catches and goes.
What could the problem be? transmission fluid is fine... the car is not driven hard whatsoever, and currently sits at 57k miles.
Old Nov 17, 2005 | 03:03 PM
YellowS2kPwr's Avatar
Seems like trans is going. You should get it checked out because it sounds like it can be fixed now easily but if you drive it like that, they tend to get messed up completely. Ask me how I know. So go check it out.
Old Nov 17, 2005 | 03:10 PM
Luke530's Avatar
yea... I figured that much, just trying to get input on what the hell could be wrong?
How are finals going BTW? I have one tomorrow at 11:45
Old Nov 17, 2005 | 03:25 PM
Greenlight's Avatar
First I'll ask the obvious dumb question. Have you checked the transmission fluid level?
If it's O.K., did the transmission fluid look red?
As the fluid deteriorates the color changes from red, to orange/brown, to brown, to dark brown, to black. If it's black you're in trouble. If is smells like burnt oil you may be in trouble.
I don't thiink the problem is the torque convertor. It's more likely low pressure to the clutch drum(s) (possibly due to a clogged filter) or worn clutches.
I would first try replacing the transmission filter, located in the transmission pan.
When you remove the pan check for debris (a small amount of tiny flakes is normal). If there is a lot of debris your transmission is in big trouble.
Greenlight
Old Nov 17, 2005 | 03:56 PM
Luke530's Avatar
filter was replaced when we changed the tranny fluid... transmission fluid is fine and red! idk?
Old Nov 17, 2005 | 04:18 PM
Slows2k's Avatar
Moving to Car Talk.
eprahm
Nov 13, 2008 08:28 AM
KrNCyK
Dec 1, 2006 06:21 PM
turbolane
Nov 11, 2005 08:04 AM
ronblanford
Jul 23, 2003 08:35 AM
jmas2000
Nov 8, 2002 04:22 PM
