The Biggest Loser: Audi A5
The Insight was a halo model (from an efficiency/engineering, not enthusiasts' perspective), limited in production but providing a huge amount of positive PR for them. I wouldn't be surprised if they lost money on every one.
Originally Posted by rjl850,Jan 27 2010, 02:23 PM
I'm curious about this comment. Can you say more? What is fatigue life and what happens when you reach the end of it? The car doesn't fall apart, I wouldn't think, but does it become less crashworthy, more "flexy", or what? And how much time are we talking? A quick check on the internets reveals that some 737s (made of aluminum), have been flying for 30 years and 60,000+ hours (and 80,000+ pressurization cycles!)....
(BTW, new to the forum
Welcome to car talk!
Curious on the same thing, and EG - thanks for the info on the Insight.
Im pretty excited about all this. Regardless of the performance potential, cars like the R8 or Murcielago weighing in at 3400/3600+ lbs is ridiculous IMO. Same applies to more pedestrian vehicles.
Im down with the "less weight, less power" concept as it'll create a better performer out of the box in every category (braking, handling, accel), yet allow much more room for improvement when it comes to aftermarket modifications, since the weight is already down and in theory, most companys would use a smaller, factory boosted motor, like Audi's 2.0T.
.)Or, as they put it on Wikipedia:
"Fatigue limit, endurance limit, and fatigue strength are all expressions used to describe a property of materials: the amplitude (or range) of cyclic stress that can be applied to the material without causing fatigue failure. Ferrous alloys and titanium alloys have a distinct limit, an amplitude below which there appears to be no number of cycles that will cause failure.
Other structural metals such as aluminum and copper, do not have a distinct limit and will eventually fail even from small stress amplitudes
Originally Posted by RabidRat,Jan 27 2010, 01:17 PM
there's a speaker in the cabin to pipe the engine sound through? how long til whistle tips come standard from the factory?
smaller brakes off the A3 to save a couple pounds?
WTF.
WTF.
Smaller brakes are adequate to stop the car at the same rate as the original brakes/weight since the car weighs less.
What's also impressive to me is that (although this is a concept), it's the first car with these power ratings (211 HP/~250 TQ) to run low 14s in a while.
Originally Posted by rjl850,Jan 27 2010, 03:53 PM
Interesting. Thanks for the reply. So do you design for a maximum number of cycles that you think won't be exceeded? Sorry for the barrage of questions, but do you know what, say, 100,000 cycles means with respect to a car's lifespan?
Again, the killer is stress RANGE, not just the absolute level of stress. If you're only loading the car gently for most of its life, it's not too bad (no big spikes in load on a regular basis). However, if you're racing or running it hard, it's a bigger deal.
The other thing is, depending on where you put the aluminum, you can effectively isolate it from high-stress cyclic loading.
All else being equal I'd still rather have the lighter car, but just wanted to point out it's not a complete win.
WTF.
WTF.
Originally Posted by JonBoy,Jan 27 2010, 02:00 PM
You design for what amounts to "infinite" life. 100,000 cycles is nothing for a car. Try hundreds of millions, probably billions, of cycles. Every bump you hit in the road is a cycle. Every time the engine changes rpm (changing torque), it's a cycle. Every time you turn the steering wheel, it's a cycle. Every time you slow down or stop, it's a cycle. Basically, any thing that "changes" the current state of the car is a cycle. However, there's a big difference between hitting a speedbump at 60 mph (big jump in load) and slowly stopping the car (minor change in load).
Originally Posted by PedalFaster,Jan 27 2010, 02:11 PM
Since the car weighs less than the A3, why not?
