Blazer electrical help?
I have a '96 Blazer, 4.3l. Battery discharges after sitting for several days. Will recharge by alternator.
Test meter shows 2.5 ampere draw, way too high. Bench tested alternator, O.K., diode good, charging, no shorts, etc. Pulled ALL fuses, and disconnected any connectors and relays that I could see, still drawing excess current. Also waited for ECU to power down.
Parasitic draw of clock, ECU, and radio presets should only be milliamps.
Any ideas? Driving me nuts!
Thanx.
Ken
Thanx.
Ken
Probably missed a fuse. Perhaps you have seperate fuse blocks?
Buy a 12 volt test light. Hook one end to the negative battery post and the other to the negative cable. Remove and replace fuses until the light goes out.
richardmai92
Sep 7, 2015 04:29 AM
M@rk
Jul 20, 2004 01:12 PM
