CEL Code P1031
Old Jul 30, 2005 | 09:01 AM
revhi's Avatar
Default CEL Code P1031
P0131 Primary Heated Oxygen Sensor (Primary HO2S) (Sensor 1) Circuit Low.
This MIL is on in my girlfriends 99 Si. Ive searched around and it seems that no one has had this code pop up in either the Civic or S2000 community. Is it just a bad sensor? The car is completley stock and has about 40k. .
Old Jul 30, 2005 | 01:09 PM
Wisconsin S2k's Avatar
first try resetting the ECU.
it could be the HO2S sensor is bad. could also be a connection between the sensor and the ECU.
Old Jul 30, 2005 | 01:53 PM
Slows2k's Avatar
Usually it's a bad sensor, with a biased low output voltage. You have to monitor the 02 output voltage with the engine running to verify the sensor is bad.
If the sensor input volts stay below .5 and don't rapidly change from 0-1V, the sensor is bad.
Off to Car talk as well, cuz it's for a Civic
unowned
Apr 11, 2021 08:19 AM
sloo2k
Nov 7, 2017 11:06 PM
4x4 freak
Dec 2, 2015 10:08 PM
Mannyfresh
Jun 27, 2014 05:02 PM
Deliverance
Aug 4, 2010 07:17 PM
