Engine braking = bad?
Originally Posted by Mr.E.G.,Feb 24 2007, 09:17 PM
i heard it straight from the mouth of several professional engine builders.
engine braking is bad.
I like to think of it this way:
brake pads are much easier to replace than an engine, so I brake with the brakes.....
Regarding this statement and engines feeding gas when engine braking:
We put gas in yet it slows the car rather than makes it go faster.
Seriously people. Some of you make engine braking sound as if its so bad your going to granade the motor if you do it often. All this talk about "Brakes are cheaper than the Engine" is laughable. Its All about proper driver technique. Obviously if you dont know the proper technique then maybe one should take some driver race courses.
IT WILL NOT cause a problem. Hell our engines are fully fordged to begin with.
engine braking is a perfectly acceptable way of reducing the cars speed, especially in motorsports when using the brake would introduce a tendicy to oversteer.
Rev matching is important when you down shift to the a lower gear during engine braking. You shouldnt use the clutch to further assist in slowing the car, which is why you should bring the engine up to the proper speed before releasing the clutch upon deceleration.
I mean its really simple... acceleration to 6k engine brake down to 4k, blip throttle to 4k..downshift....engine brake to 3k...etc etc
I'm not saying engine braking is bad, i just use the brakes. I dont engine brake at every possible chance just to increase the life of my brakes like some people do.
If you're using the brakes to decelerate the car, they're doing a lot of the work, and you're slowing the car down, so the engine (since you're still likely in gear) slows down faster and with greater ease, since the drivetrain is making it rev down because the car is being slowed by another force (the brakes)
OHH
btw, just happened to think
The final blow to my VR4 that killed the engine actually happened during engine braking.
I was coming home from college, driving down the mountain, and was engine braking. Everything was hunky doory for a while, and then suddenly I started hearing this noise, pulled over, and I was missing really bad
Turns out a piston had overheated, a chunk broke off, got stuck in a valve holding it open, which allowed the cam to turn and the rocker to pop loose.
This was after maybe 2 minutes of continuous engine braking.
So yes, you can damage an engine while engine braking. True story
OHH
Originally Posted by deathsled,Feb 24 2007, 07:11 PM
OHH
[QUOTE]Ring Land Pound Out
This can occur in high output, turbocharged and supercharged engines that operate under higher temperatures and loads than other engines. If the piston alloy can
a lot more fun to "blip" downshift - my car is 6 years old and the brakes are almost new...
if there is a "cost" to engine braking, its the clutch. mine is still fine, and if i have to replace it, thats also fine-
for me, part of the fun of driving this great car is playing with the engine... and listening to the results coming outta the rear end (exhaust)-
so for me, if engine braking is more expensive that is o.k., cause without it i might as well be driving a vw bug !!
I thought this was discussed in another thread to the conclusion that modern cars (like the S2000) cut fuel supply when engine braking and the engine essentially pumps air until the rpms reach idle speed or the accelerator is pushed.
just giving you a hard time.
