How does a LSD
Originally Posted by rockville' timestamp='1301890654' post='20426466
Conversely I think the LSD makes you faster in cases where you have more power than grip. That would include low powered cars with crap tires or high powered cars.
Don’t take all of what I have said to mean a LSD is a bad thing in a car. Most of the time it does make you go faster and does get the job done. It’s not a perfect solution. You might have missed it but this discussion came out of the McLaren thread. There was a critical comment that McLaren would have been better with a LSD instead of the brake based system they used. I actually think that, from a performance POV, if well executed a brake system is superior to a LSD in just about every way.
My 2x $.02 = $.04!
At first I also thought a brake based system was dumb because you were burning up power vs transferring it to the other wheel. Of course the other issue with a brake based system is does it actually work well? A LSD is flawed in how it distributes torque but it can be made to operate very smoothly. However, just about any time (I haven't proven to my self that the real answer is ANYTIME) you have enough power to cause one wheel to slip you have more power than you can deal with (ie more than the tires will put to the road at this moment). That means the power you are putting into the brakes would otherwise be wasted (or not requested by reducing throttle). Even when your power to weight ratio is modest I believe a GOOD brake based system will offer better performance. I do not believe it will be cheaper or easier to implement.
Originally Posted by ZDan' timestamp='1302092578' post='20435145
[quote name='rockville' timestamp='1301890654' post='20426466']
My 2x $.02 = $.04!
Mini Cooper Ss are no longer available with the mechanical LSD option. The LSD used to be a $500 a la carte build option that was pretty much the best bargain on the Mini options list. In 2011s model year, the LSD was discontinued and a new brake-based "Electronic LSD" replaced it. Strangely, the new "Electronic LSD", even though it was nothing more than software code in the ECU, also costs $500. Minis with the LSD are fantastic track day cars because they are lightweight cars and come with phenomenal brakes from the factory. Overheating brakes are rarely a serious issue with a Mini on a track day. The owners of 2011+ Minis with the Electronic LSD report that, regardless of what brake pads or fluid they use, the brakes overheat and turn to mush within 2 or 3 laps due to all the extra braking generated by the Electronic LSD.
Andrew
[/quote]
I believe the loss of power argument is a non-issue as at the time you are using the system you have an excess of power (hence the wheel slip). I don't disagree with the brake heating issues. This is why I have to qualify the claims with well designed and I also make no claims as to service costs etc. I wouldn't claim the brake based system is the best compromise, only that it does a better job of managing the torque to the wheels.
Mini's pricing to the consumer isn't a good data point. Mini charged $240 for cruise control in the cars. Since the car is throttle by wire cruise control is the cost of the switches in the dash. I have no idea what changes were necessary to implement the current ELSD in the car. I wouldn't assume it to be trivial but I also don't know what base hardware is already in the car. Finally, as I have said, compromise. I never said the ELSD was going to be the best compromise, only that if done well it would have better torque management.
As I've said before, many cars are faster with the LSD. I have one in my car. I'm aware of both the pros and cons. I wrote the original post because it was clear in discussions in another thread that people didn't understand how the diffs worked or even that they could have drawbacks. Even if we are willing to accept those drawbacks, I have explained why they fundamentally exist. Some people don't believe they even exist.
Actually the more grip you have, the greater the need for LSD. The greater the cornering grip, the more you unload the inside drive wheel. Even with low hp, if you have enough grip to unload the inside wheel you'll get inside wheelspin.
FF is of course a totally different story.
But if you had a proper LSD, it would mechanically transfer the power from the wheel with less grip ("an excess of power") to the wheel with more grip (not enough power) to help accelerate the car out of each corner faster... With the "electronic LSD", that engine power that could otherwise be partially transferred to a wheel with more grip to help accelerate the car is instead turned into heat and noise by the brakes.
I just thought that Mini's option pricing scheme was more amusing than anything else.
Sticking to the Mini example - It's well known that a Mini Cooper S with the mechanical LSD has significantly more torque steer than one with an open diff. And this certainly supports your earlier point that from a feel and drivability perspective, an LSD is sometimes not ideal. However from a performance perspective, the Mini with the LSD is always going to offer superior performance to an identical Mini with the open diff.
Andrew
Originally Posted by rockville' timestamp='1302100110' post='20435627
[quote name='ZDan' timestamp='1302092578' post='20435145']
FF is of course a totally different story.[/quote]
No, the FF is simply at extreme of a continuum. Whether or not a LSD helps and how much it helps depends on many things. I have a friend who used to track his Miata all the time. He used summer only street tires but nothing as aggressive as R tire. He didn't have any issues with inside tire slip thus a LSD wasn't necessary for his car as he was driving it. With a different setup it would be helpful. The point is don't automatically assume the LSD will make you faster and certainly don't assume it will make the car handle better. Of the latter point it almost certainly will be neutral to negative even if it lowers lap times.
Also, remember the other issue, to get the torque transfer to the outside tire I have to let the inside tire spin faster than the diff. Ideally I want the inside tire to spin at some speed that maximizes it's grip. That speed is going to be just slightly faster than the road speed. If it spins faster than that I lose grip. Thus I am better off with a system that let's me control torque AND wheel speed independently. An e-LSD system does that. I control torque to the outside wheel via the engine. The inside wheel has excess torque AND speed so I use the brakes to apply enough slowing torque so that the wheel speed is "ideal". Because I have two control inputs I have a more controllable system.
With an LSD I can only control total torque into the system. So I push the engine so the outside tire is on the verge of slipping and can't accept any more torque from the engine. Now the inside tire is spinning faster than the road. It's spinning faster than I want and thus doesn't grip as well as a tire spinning at just the right speed. The only way to slow the inside tire is cut torque to both. That slows me down because I no longer get to send the ideal amount of torque to the outside tire. I have a less controllable system because I have only one control input.
Andrew
Andrew
Originally Posted by ZDan' timestamp='1302108725' post='20436322
[quote name='rockville' timestamp='1302100110' post='20435627']
No, the FF is simply at extreme of a continuum.[/quote]
With a c.g. height on the order of 1/2 that of my similar power/weight 240Z with similar track width and wheelbase, and with a significantly greater %age of its static weight on the drive wheels, a FF *is* a totally different story as far as the need for a limited slip is concerned. Even allowing for its greater cornering g's (probably ~1.2x that of the Z on Hoosier A6s).
Originally Posted by rockville' timestamp='1302111375' post='20436542
[quote name='ZDan' timestamp='1302108725' post='20436322']
[/quote]
The same rules of vehicle dynamics apply thus a continuum.
