How does a LSD
Cheaper to make the car without LSD, plain and simple. If you ask the manufacturer, I'm *sure* they'll have a good reason other than that (like: "but it *feels* better without lsd"), but that's the bottom line.
Used to be able to get an LSD on the lowliest BMW 318i, now you have to get an M-car to get an LSD
Same w/ Porsche. You can no longer get an LSD on a base 911, you have to get a 911S.
Shenanigans!
Shenanigans!
No, the FF is simply at extreme of a continuum. Whether or not a LSD helps and how much it helps depends on many things. I have a friend who used to track his Miata all the time. He used summer only street tires but nothing as aggressive as R tire. He didn't have any issues with inside tire slip thus a LSD wasn't necessary for his car as he was driving it. With a different setup it would be helpful. The point is don't automatically assume the LSD will make you faster and certainly don't assume it will make the car handle better. Of the latter point it almost certainly will be neutral to negative even if it lowers lap times.
I am not saying that an LSD is better in EVERY situation, but I would say that it is better for RACING, on a road car based race car. There is a reason that every Spec-Miata driver there is either has or wants a LSD in their car.
However, to back what you have said, I have heard that the various Miata class racers want the LSD to lower their lap times. Of course the Miata has a relatively short wheel base and track and consequently the ratio of CG to footprint might be less favorable than many realize.
he didn't feel it was a significant issue on the race track and was happy with the open diff and more so when he realized the negatives the LSD can have on the handling of the car when you have less than sticky tires or the roads aren't dry and clean.
That said, there are times that I wish that I had a bit more rear end compliance for rain races. But that can be solved by me not being lazy and un-hooking the rear sway bar.
First, let me state that the degree to which a LSD will negatively affect handling is dependent on many things. In some cases it's going to be transparent in others it will not. Don't take my handling points to mean ALL cars with a LSD will have problems. Also, remember that not all LSDs are equal. The BMW M diff would likely have basically no ill effect on handling as it is a speed dependent diff. A torque sensing diff is more likely to have some of these issues while a fixed force spring clutch pack is most likely. The setup of an individual car will also make a big difference. I first noticed the issue with my car because the previous owner had installed economy tires with little grip or compliance on the car. Replacing the junk tires with decent, grippy tires largely fixed the issue but got me thinking about the original issue. Also, when I say issue I don't mean the car handles "badly". My personal car had a LSD and I don't think it handles badly. However, I do notice the negative side effects of the LSD from time to time.
The fundamental sources of a handling issue due to two things we have mentioned in this thread. One, the diff will basically behave like a spool in conditions where the difference in forces on the left and right tires are less than sufficient to allow the wheels to move independently. Two, the diff sends torque to the inside wheel of a turn under normal conditions.
One becomes apparent when driving on say gravel or other low grip surfaces. It manifests as the rear end wants to step out very easily. Sure that's fun if your intent is to drift around every corner but mine often is not. In snow this can be particularly problematic as the rear end tends to shift sideways very very easily.
The other is a sometimes noticeable tenancy to understeer. Most people think about power oversteer with a LSD. That is an issue and certainly had lead to a few Miata's smacking their rear wheels into curbs. If you read one of the "it just stepped out on me" stories on the Miata forum you will find that often the car had a LSD. The open diff cars don't surprise as much because they just spin the inside tire and slow down. So I think we can all see the oversteer part. The understeer comes from the torque transfer I've been talking about. I drive on a number of gravel roads. With my open diff Miata I never noticed a tendency for the rear to want to come out under power. With my LSD car the car clearly understeers into the corner as the rear axle applies more torque to the inside tire and tries to keep me going straight. Once the turn gets going it's easy for the car to transition into oversteer as is common with a LSD. This basically makes the whole turn less fluid than with the open diff car. The open diff car doesn't put the power down as well but the rear axle doesn't fight the front wheels.
With hard tires or say in the rain, this same issue can be felt. However, in the dry with good tires the extra grip of all 4 tires masks this behavior and all is fine. I have theorized about this though I haven't run the numbers. Here is my thought. The behaviors I'm talking about and noticing happen at less than 100%. For instance, I might take a particular turn at 35 mph. That is a safe speed in rain or shine. Well in rain I might be at say 85% of my tire's grip. In sun perhaps only 40%. What does the diff see? Well it takes basically the same power to push me through the turn rain or shine. That means the diff see's the same input torque and so long as the wheels aren't slipping the wheels deliver the same torque. However, in one case we are far from the limits of the tires. In the other case we aren't that far from the limits. We start feeling the behavior as the tires get to their limits due to the transfers of torque and as the front tires get to their limits while trying to rotate a rear axle that is fighting their action. Net result the rain makes the feeling obvious at low speeds because we have limited the performance of the tires.
I did a search for other sources mentioning the same things I'm discussing. Here is part of a book about the creation of the GT-R mentioning much of the same stuff.
http://books.google.com/books?id=0JW...page&q&f=false
Note that the understeer is caused by the mechanisms I mentioned on page 1.
The emphasis is mine and is exactly what I have been telling Nunco, the slower wheel gets more torque!
The article goes on but I have to hand copy it. Basically it agrees with everything I've been saying and also explains why Nissan elected to go with active diffs rather than traditional passive/mechanical LSDs for the GT-R.
Originally Posted by page 63
By limiting rotational speed differences between the left and right wheels a limited slip final drive increases the car's traction. Usually an unfortunate consequence of this is understeer, but, if during cornering the inner wheel is sufficiently unloaded, and a lot of torque is applied, the LSD transmits the torque to the outside wheel provoking oversteer
Originally Posted by page 62-63
The 'viscous-mechanical' LSDs, like those developed by Ricardo Motorsports, react on both torque application and speed difference. By locking the clutch-type LSD the difference in the speeds of the driving wheels decreases and torque is transferred to the slower wheel (with better traction)
Mechanical LSDs may increase performance in certain driving situations but can negatively affect handling in others. By making the driving wheels rotate at the same speed, the LSD causes understeer. At the same time as it transfers torque from the faster wheel to the slower one, the LSD can induce either understeer or oversteer.
Braking into a corner, LSDs (except 1-way clutch-type LSDs, but including helical torque-biasing LSDs) always create understeer: the inner wheel is always slower than the outer one because the curve it traces has a shorter radius, so the torque is transferred to the inner wheel. When the speeds of the wheels equalize, understeer occurs.
In mid-corner when just a moderate amount of torque is applied and the inside wheel does not spin, the LSD transfers the torque to the slower (inside) wheel, causing understeer. The same can happen even in a corner exit if the inside wheel does not slip as torque is applied. However, if torque increases and the inside wheel starts to slip, which happens frequently when a car starts to accelerate out of a corner, the LSD starts to lock up to bias torque to the outside wheel, causing the car to oversteer. Depending on the corner radius, the road surface, the vehicle speed and power, the longitudinal and lateral acceleration , and the characteristics of the tires, the LSD could transfer enough torque to the outside wheel to break its grip and initiate a power oversteer and a sideways slide. This is why a car with neutral handling could become an exciting (if not dangerous) drifer after being equipped with a LSD; particularly a locking-type LSD which transfers torque more aggressively.
See, here's one issue. If you experience understeer at the beginning of a corner, the way you are driving and the way the car is set up are not compatible. One might more accurately say that open diffs are slower because they make the car harder to rotate and cannot put power down around a corner. The fact that they require slightly different driving is indicative of their function.
In addition, much of what you just quoted is inaccurate or an over-simplicfication. As you know, there are numerous LSD types and variations of design with a particuilar type. So any statement such as "LSDs (except 1-way clutch-type LSDs, but including helical torque-biasing LSDs) always create understeer..." (3rd quote) are just ludicrous. One can adjust the behavior of clutch type designs. It is the degree of those adjustments that make a diff a 1-, 1.5-, or 2-way, and one would expect those adjustments to be intentional. So if understeer was an issue because of your adjustments, you'd fix it.
Furthermore, if you consider the LSD's behavior in a straight line a "trivial case" despite the fact that a stright line is perhaps the most common situation, how can you consider driving around a curve with both wheels having equal traction anything other than a trivial case? I would like to see the super-common situation you are imagining whereby the inside wheel, despite being unweighted, has more traction than the outside wheel. How often does that happen in real life?
Note that the article said exactly what I said about that, the slower wheel gets the torque. With that in mind if you give the slower wheel the torque that means you create an understeer moment about the rear axle. Thus the statement is accurate. You seem to have trouble separating the behavior of the chassis from the forces the diff applies to the car (via the wheels).
I find it disappointing that the moment I present some article that backs 100% of what I have said it's "inaccurate". What article do you have that suggests otherwise?
Do you now agree based on both what I have said AND the claims of this article that a passive LSD will transfer torque to the slower of the two wheels any time we have a difference in wheel speeds? I think that is a critical question since I believe it is one we disagreed on.
As for understeer dynamics of an lsd, I guess that there maybe some small amount that this does effect, but on a track, I would still have my money on the one of two identical cars an drivers that had an LSD rear end. I am guessing that there is a reason that pretty much every form of professional racing uses LSD's.
So if I were to agree with someone on something, it would be that for someone who is not comfortable with any rear end movement, an open diff is better, For a better driver, an LSD is better for most scenarios.
I would alter your last sentence to say the LSD is faster. Better is subjective. I often prefer the more fluid feeling of an open diff. A carefully balanced car will allow you to feel the action of the LSD. Now that I know what to look for I notice it rather quickly and don't care for it... unless hanging the tail out is my objective in which case I love the LSD.
Nunco,
I did some additional digging on the subject. I hope the following papers and presentation will convince you that my description was correct. The papers are by the same group out of U of Minnesota. One is an SAE paper the other is an IEEE paper. Both papers are peer reviewed. The presentation is by Eaton Corp though it also is in connection with the same group of researchers. The researchers were looking at electronically controlled LSDs and center couplings for AWD vehicles. The materials include information about rear LSDs which would be relevant to our discussion. Given the parties involved this should be considered authoritative.
http://ghost.engin.umich.edu/tcac/8_workshop06_lew.pdf
http://www.me.umn.edu/~qhyuan/public...TorqueBias.pdf
http://www.me.umn.edu/~qhyuan/public...06-01-1963.pdf
The first link includes a great diagram and the equations that define the torque flow through the diff. On slide 8 we have a model of a clutch based LSD. In this case they model the clutch as only a single unit rather than a pair. At first this may seem odd. However, because the left and right outputs are coupled via the spider gears a resistance on one is applied to both. So even though I have been describing things with a pair of clutches there really is no reason to have two nor would the two need to be equal in size. The last paper (the SAE paper) shows a LSD which has a hydraulically controlled clutch on just one side of the diff. I think it's safe to say that if Eaton Corp felt they didn't need to put clutches on both sides of the diff we can assume that the locking torque of the pair of clutches is the sum of the individual clutches. I have typically referred to T_clutch as the torque that is needed to rotate a single clutch so what the presentation calls T_tf is what I would have called 2*(T_clutch).
So on page 8 along with a schematic of a diff the presentation has some equations for the torque applied to each wheel. Those equations follow mine though the actual names of the variables are different. Let's identify the parallel terms:
Note that since I had effectively two T_clutches and since I called the T_diff = 2*T_spider the peer reviewed papers and I ended up saying the exact same thing! The torque delivered to each wheel is the sum of the torque from the spider gears (which is in the same direction) and the torque from the clutching system which is added to one output and subtracted from the other!
Now look at slide 9. Note the following two points.
These are the points I was talking about all along. Yes, my musings were only those of a random car enthusiast but it's clear they parallel the understandings of experts at both Eaton corp and U of Minnesota. I would say that is pretty darn conclusive. While I found some of this discussion trying as I struggled to try to explain these concepts in the and I think this was a good discussion and hopefully others came away with a new understanding of what a LSD is good and not good for. I certainly came away with a much better understanding of how to describe the inherent function of the system.
- I have said T_diff is the torque rotating the whole diff housing (eg the torque from the engine). They call the torque from the engine T_p for propshaft. They also note an assumed 1:1 final drive ratio to keep the math easier to follow.
- The torque transfered by the clutch system is T_tf. In there system T_tf is controlled by a computer where as we have been talking about passive systems where T_ft would be controlled as a function of relative wheel speeds (speed sensing) or as a ratio of T_p as a torque sensing diff. The fact that in this case the magnitude of the clamping force on the diff is computer controlled does change things in that the computer can choose to release the clutch when the properties of an open diff are more appropriate. However it could also be programmed to perfectly mirror a Torsen diff. We would simply measure the torque into the diff and apply clutch clamping pressure accordingly. Net result, even though the control strategy for this diff could be more complex than say a Torsen, the torque flows will be the same and its affects on the handling of the car would be the same if programmed to behave as a torque sensing diff. In short, don't claim that because this is an eLSD the information doesn't apply.
- What they call T_diff I was calling in effect 2*T_spider. That is the torque the open differential gears apply to the outputs.
- Because their model has a clutch only on one side they have to show how the one sided clutch can affect both outputs. They show that math on the same slide. The final result of the math is T_l=(T_p +T_tf)/2 and T_r=T_p -T_tf)/2. I said T_l=T_spider+T_clutch and T_r=T_spider-T_clutch.
- Transfers torque from the faster speed wheel to the the lower speed wheel.
- Increases vehicle yaw understeer tendency on a constant mu surface
You should examine the papers again. All three use T_diff for the torque transferred by the driveshaft, T_CT_r for the torque transferred by the clutches, and T_lr and T_rr for the torque at each axle.
In their math, T_lr = T_CT_r + (T_diff/2), while T_rr = 9T_diff/2). This clearly shows the clutches imparting torque to the side axle they are mounted on, and their system is not the same as one with clutches on both axles. One with two sets of clutches would feature T_CT_lr and T_CT_rr. According to their math, a system with a set of clutch stacks on both sides would be T_lr = T_CT_lr + (T_diff/2) and T_rr = T_CT_rr + (T_diff/2).
They clearly show that the people writing the papers feel that torque is transferred based on how tightly the clutches are bound. If you put clutches on both sides, then the side with more tightly bound clutch stacks would be transferring more torque.
I do see slide 9. And yet again, the slide is doing what you did - only addressing one half of the equation. It leaves out entirely the forces countering the engine torque. The engine cannot generate torque if there is no conteracting force. For instance, if the wheels are off the ground, a gasoline engine cannot generate any more torque than is required to spin the wheels. As such, if one is going to model the behavior of a system such as a limited slip differential, one needs to include both the torque of the engine and the reaction torque of friction, et al.
In other words, when you leave out half the equation, you get a wrong answer. I don't care if it is peer-reviewed or not, my physics professor would never accept that work.
The inside wheel is unweighted. It cannot transfer as much torque as the outside wheel. If it tries it will slip. Luckily with an LSD it will only slip at the same speed the outside wheel is moving, making perhaps one unnecessary revolution around the course of the turn. Not much of a slip, and doubtful that an observer would even notice.
Again, papers are paper. Show me a situation where the inside wheel has the same traction as the outside wheel despite being unweighted. Because the outside wheel can only transfer more torque than the outside wheel when it has sufficient traction. And we know even on a Miata that is going to be a rare case, otherwise nobody would spin the inside rear wheel with an open diff.
What I am saying is that a situation where an LSD actually causes understeer during a corner while under acceleration due to the inside axle tranferring more torque to the wheel is so remarkably rare it is not a consideration. The inside tire is going slip slightly far more often.
Just because those people wrote a paper does not mean the real world matches their simulations. Also, if you read the second paper, near the beginning it highlights the lack of relevant works at this level. Which is the situtation I also found.
IMHO, the circumstances described in the papers as "high friction surface" is a rarity, not a common situation. I think many non-engineers have already disputed what you and the papers claim. I'm not sure how long one is expected to insist on papers trumping observed reality, but I think it's past time to concede the issue.
I appreciate you finding and posting the papers, and have saved them for future reference, but I also take them with a grain of salt.
