View Poll Results: HP -> Acceleration... not Torque!
HP is more important than Torque
58.62%
Torque is more important than HP
41.38%
Voters: 203. You may not vote on this poll
Old Jun 13, 2003 | 11:21 AM
  #241
rai's Avatar
rai
Destiny2002, I think I understand the dyno a little better (thanks). The thing is we are talking about is acceleration, and it seems that the ENGINE is only one factor, the gear ratio, transmission, and wheel size and weight (rotating mass) all have a role in acceleration.
BTW why do you think Honda doesn't put a 4.44 ratio in the S2000, except for gas mileage I can't think of a thing it does worse than the stock.
Old Jun 13, 2003 | 11:24 AM
  #242
Destiny2002's Avatar
Old Jun 13, 2003 | 11:25 AM
  #243
wc_one's Avatar
[QUOTE]Originally posted by Destiny2002
[B]No, an engine can produce 20 ft*lb at the engine and 100ft*lb at the wheel.
Another engine can produce 200 ft*lb at the engine and 50 ft*lb at the wheel.
The engine producing more torque does not produce more acceleration in this case.
Old Jun 13, 2003 | 11:27 AM
  #244
wc_one's Avatar
No, in this case engine torque was not changed, gearing was.
(When somebody says "torque" without qualifying where the torque is measured, it's assumed to be at the crankshaft)
Horsepower wasn't changed either. So what caused the increase in acceleration? Hmmmmm...... HP != Acceleration
Old Jun 13, 2003 | 11:43 AM
  #245
Old Jun 13, 2003 | 11:48 AM
  #246
Zoran's Avatar
[QUOTE]Originally posted by wc_one
[B]
Old Jun 13, 2003 | 11:50 AM
  #247
Old Jun 13, 2003 | 11:52 AM
  #248
Zoran's Avatar
[B]
You said "at any given time".
Old Jun 13, 2003 | 11:53 AM
  #249
wc_one's Avatar
Let's go through this step by step.
You change gear ratio from 4.1 to 4.4.
Acceleration increased.
Engine power did not change.
Engine torque did not change.
Wheel power did not change.
Wheel torque increased.
Hence, Torque -> Acceleration... not HP!
Old Jun 13, 2003 | 11:57 AM
  #250
wc_one's Avatar
[B]
You said "wheel torque... is determined by engine torque. "
This is incorrect.
