View Poll Results: HP -> Acceleration... not Torque!
HP is more important than Torque
58.62%
Torque is more important than HP
41.38%
Voters: 203. You may not vote on this poll
Old Jun 13, 2003 | 11:58 AM
  #251
wc_one's Avatar
Originally posted by Zoran
Let me start:
Without RPM, there's no acceleration. Therefore RPM -> Acceleration!
That is incorrect. F = m * a. RPM/speed/velocity is nowhere in the equation.
Old Jun 13, 2003 | 11:59 AM
  #252
Destiny2002's Avatar
Old Jun 13, 2003 | 12:00 PM
  #253
wc_one's Avatar
Horsepower HAS changed. By changing gearing you move the engine to different RPM, and therefore different HP.
So I'm at HP peak, change the gearing, I'm now at a higher RPM but less HP and accelerating faster. So you're telling me less HP equals more acceleration???
Old Jun 13, 2003 | 12:01 PM
  #254
wc_one's Avatar
Old Jun 13, 2003 | 12:05 PM
  #255
Old Jun 13, 2003 | 12:07 PM
  #256
Old Jun 13, 2003 | 12:13 PM
  #257
Elistan's Avatar
Originally posted by wc_one
Let's go through this step by step.
You change gear ratio from 4.1 to 4.4.
Acceleration increased.
Engine power did not change.
Engine torque did not change.
Wheel power did not change.
Wheel torque increased.
Hence, Torque -> Acceleration... not HP!
Good God.
a = F /m.
IT IS TRIVIALLY OBVIOUS THAT ACCELERATION ONLY HAPPENS WITH THE APPLICATION OF FORCE!
Your above post is 100%, completely correct. You're completely missing the point of this discussion, however. Anybody who disputes the basic F=ma formula has no concept of the most basic level of physics, and nobody here will dispute it.
THE CURRENT DISCUSSION IS ABOUT WHETHER THE CRANK TORQUE NUMBERS OR CRANK HORSEPOWER NUMBERS ARE THE BETTER INDICATION OF A CAR'S POSSIBLE RATE OF ACCELERATION!
When all factors are accounted for (crank torque, redline, gearing, tire size, car weight, etc.) it turns out that the pounds per hp (car weight per crank horsepower) stat is the absolute best simple correlation between those stats and various cars' relative maximum accelerations. (Wile the absolute best complex method is, of course, to run the crank torque though the gearing, tire size and the like, come up with a pounds of thrust value, which given the car's weight can be used to calculate the actual acceleration in G's. But 99% of car consumers out there would be unable to do such a calculation, I bet. Hence, the next best thing - pounds per hp. Personally, I think it'd be great if car manufactures would do the calculations for us and give us the pounds of thrust stat.)
If two cars have 10lbs per hp, they will accelerate nearly identically even if one has twice the crank torque of the other.
Old Jun 13, 2003 | 12:21 PM
  #258
wc_one's Avatar
[QUOTE]Originally posted by Elistan
[B]Good God.
Old Jun 13, 2003 | 12:28 PM
  #259
Zoran's Avatar
[QUOTE]Originally posted by wc_one
[B]
That is incorrect.
Old Jun 13, 2003 | 12:31 PM
  #260
Zoran's Avatar
[B]
