NA Engine BMEP
Old Feb 23, 2004 | 06:16 PM
  #21
steve c's Avatar
Who gives a rats ass when it drives the wrong pair of wheels.
Old Feb 23, 2004 | 06:30 PM
  #22
cfusionpm's Avatar
Old Feb 23, 2004 | 07:42 PM
  #23
rockville's Avatar
FRM,
It
Old Feb 24, 2004 | 09:08 AM
  #24
Penforhire's Avatar
I think this stat is another useless geek quotient. A quote from your link: "It can be said a high BMEP and a low rpm, or a low BMEP and a high rpm, can equal the same power."
I don't even care if an engine is NA versus FI. The point is how they feel and perform in terms of throttle response, power output, weight, gas consumption, and durability. Packaging is important to a particular body size/style but is otherwise just a compromise (6's should be straight, V's should be 90 or 180 degrees, ...).
Old Feb 24, 2004 | 11:52 AM
  #25
AbusiveWombat's Avatar
FRM - I could be wrong but here's a pretty general rule of thumb. Any formula that contains: HP/Liter is useless for comparing street cars.
Old Feb 24, 2004 | 03:54 PM
  #26
FCGuy's Avatar
Great post Rockville!!
Old Feb 24, 2004 | 06:20 PM
  #27
FRM's Avatar
FRM
rockville,
The LS1 is popular in engine swaps. The Corvette V-8 family offer good power-to-size ratio. However, you did not mention the negative impact of a 500-lb engine on a small car
Old Feb 24, 2004 | 06:21 PM
  #28
FRM's Avatar
FRM
Valve-gear Design
Engine size is important for front-engine cars.
DOHC is the way to go for Inline-engines. V-engines have several options.
Push-rod OHV [eg Corvette LS1 V-8]
Pros: compact size (V-engines only)
Cons: limited to low rpm (heavy valvetrain), poor airflow (2 valves per cylinder)
DOHC [eg Acura NSX V-6]
Pros: allows high rpm (light valvetrain), good airflow (4 valves per cylinder)
Cons: large engine width (V-engines only)
SOHC [eg Acura TL V-6]
Combines the advantages of OHV and DOHC (V-engines only).
Acura TL V-6 cutaway view
http://www.vtec.net/articles/view-article?...ticle_id=132588
Click on image to enlarge.
Old Feb 24, 2004 | 07:37 PM
  #29
rockville's Avatar
FRM,
You are correct, the Miata V8 engine swap is a good way to add some pounds to the front of the car. Then again who was the crazy fool who first thought
Old Feb 25, 2004 | 06:25 PM
  #30
FRM's Avatar
FRM
rockville,
VW may be the king of the most displacement per space under the hood, but their W-engines are disappointing.
Acura TL V-6 vs. VW Passat W-8
BMEP
Acura TL Sedan V-6: (270 * 13000) / (3.210 * 6200) = 176 psi
VW Passat Sedan W-8: (270 * 13000) / (3.998 * 6000) = 146 psi
Cost - Base Price
TL: $33,195
VW: $40,735
0-60mph Acceleration
TL: 5.8 s
VW: 6.7 s
5-60mph Acceleration (driveability test)
TL: 6.5 s
VW: 8.1 s
EPA City Fuel Economy
TL: 20 mpg
VW: 17 mpg
http://www.caranddriver.com/article.asp?se...3&page_number=1
volume- GM 3.5L V6 and LS6
The Chevy Malibu OHV V-6 is an iron block engine. It has a low power/weight ratio.
The best GM engine will appear in the 2006 Corvette C6 Z06.
