Proton flush mounts install help!
Old Feb 7, 2008 | 09:36 PM
3vilmonkey!'s Avatar
Default Proton flush mounts install help!
Ok, I'm having a slight problem here.
I am trying to setup my signals for strobe, and when I do, the way I wire it makes them stay on no matter if the signal button is on or off.
Here is my little diagram:
The weird thing is if I take the yellow wire out of the equation, the signal operates normally but without the strobe that I want.
What have I done wrong?
Thanks!
Old Feb 9, 2008 | 12:31 AM
Angelus1243's Avatar
I really wish I could help, but I just had to say that's a sweet diagram.
Old Feb 9, 2008 | 07:16 PM
haha nvm I figured it out and they are installed.
Old Feb 9, 2008 | 10:29 PM
Jacko's Avatar
I know you said you figured it out but I thought I'd post this in case you wanted to change the blink or something
RED wire goes to OEM running light wire
Black wire goes to OEM ground wire
now you connect one or two of your remaining wires to the OEM blinker wire depending on the effect you want
Normal blink you connect Orange wire ONLY
For Strobe blink connect Yellow wire ONLY
For Fade in and Fade out blink connect BOTH Orange & Yellow wires
You also can check out there web site Proton Web Site but its just going to tell you what I just told you
Good luck hope this helps
Old Mar 5, 2008 | 08:21 PM
Broken2G's Avatar
Jacko - your sig video has to be one of the funniest iv'e seen in a while
Sorry a bit off topic
chefs2000
Feb 1, 2016 05:06 PM
TerminatioN
Mar 16, 2012 01:32 PM
robs2g1
Aug 26, 2011 06:23 PM
siadam
Jul 3, 2010 08:59 AM
07GPWvert
Jun 5, 2008 04:13 AM
