Try to build a cheap track car...
Hey guys, just wanna get some idea of which car I should use to build my cheap track car. I'm currently driving a CRX Si as a beater and kinda looking to either mod it or sell it and get a miata to build it up... any of you out ther had moded these cars before and how did it hold up?
Both are good cheap track cars and are about equal in speed with comparable modifications. I've owned both and unless you plan on big hp, the CRX is my pick for the better choice in your case. Parts are cheaper for the CRX and it is easier to work on. At low power levels FWD isn't much of a disadvantage and because of the CRX's short wheelbase, it doesn't have any problems rotating. Since you already have a CRX you should be knowledgeable about it which gives it a leg up on a Miata as well.
Depends on the tracks you'll be visiting. A miata will probably be the better choice on faster tracks.
They're both excellent choices for track use... I guess you should compare prices of modifying and stuff before you make your decision.
I personally would get the CRX since they are lighter.
Originally Posted by Shinigami,Aug 17 2006, 06:11 AM
Miata. You can strip her out to less then 2000lb's if you're brave, and then throw a V8 inside
But thanks for all the input! Please keep the idea or comment coming
Don't worry about power as the CRX has enough to get around the track and still have fun. Your money would be much better spent on more track time, tires, suspension and a LSD (in that order). When you are the point where you can't go any faster with what you've got then upgrade your engine or switch to a faster car.
