Air Con Broken?
Old Apr 16, 2007 | 02:17 AM
MGrant's Avatar
Default Air Con Broken?
Honda Accord Sport;year 2000. The air con has just become pretty inneffective. Any ideas?
Is regassing a good starter for ten.I would assume some independant garages are cheaper than a dealer?
I`m near Gatwick if abyone has used someone who they`d recomend
Cheers for any tips
Old Apr 16, 2007 | 04:13 AM
WRumbled's Avatar
Most places will re-gas with a dye so that they can spot any leaks. Unless there's an obvious problem, that's what they'll do before trying anything else.
My beater needed a new condenser last year; only
Old Apr 16, 2007 | 04:40 AM
jml's Avatar
jml
Checking & repairing AC car systems is a specialist's job (equipment & knowledge). A honda dealer or an independent will probably just play middleman and you'll pay for the privilege.
So do find one in your area.
Old Apr 16, 2007 | 04:45 AM
ADP's Avatar
ADP
Got mine done for about
Old Apr 16, 2007 | 07:43 AM
MGrant's Avatar
Thanks.I`ll get the yellow pages out
Old Apr 16, 2007 | 11:27 AM
Simoted's Avatar
When I bought my car the air con did not work at all, just blew out warm air. I borrowed a pressure gauge and aircon gas canister off a mate (bought from halfords). topped it up to the required pressure and its as good as any new car I've ever had. Just thought I'd mention it
Old Apr 17, 2007 | 12:08 AM
ADP's Avatar
ADP
you are brave
having seen the guy do mine I was scared shitless - Id be very wary of doing a DIY myself
Old Apr 17, 2007 | 12:17 AM
Nick Graves's Avatar
WTF?
It's just like filling a lighter, surely?
Only without all those adaptors, none of which fit so you get covered in LPG.
Old Apr 17, 2007 | 12:47 AM
jml's Avatar
jml
Well Nick the adapter although rather expensive is more or less universal for car AC but it isn't a simple matter of filling it up..
The need for a vacuum pump fe springs to mind. Then oc the right amount of gas has to be taken into account (special scales)...and so it goes on..
And all this under the assumption that there's no leak (hard to find sometimes) and that a lack of gas is the culprit . Could be the compressor too fe...
In short stay clear
Old Apr 17, 2007 | 01:31 AM
senninha1994's Avatar
When they regassed my old beaters AC the guy explained what it actually does.
IIRC it removes all the coolant cleans it and refills the system with the correct amount, topping up where necesarry.
